Howdy ya'll
I have a 2023 GMC Sierra Denali Ultimate with the 6.2 V8. As soon as I bought the truck (@400 miles) I had a local shop, 5RTrucks out of Golden, CO, install a 4 inch BDS lift and install 35 inch tires. At 19,000 miles I got three warning lights (Brake System Failure would not let me go over 42 MPH, Service ESC, Trailer Brakes Disabled). I took it to the dealership. They have attempted to fix the problem now 5 times. They have replaced the brake module, performed a brake flush, performed software updates and replaced a sensor and wiring harness. Each time they have given me the truck back, I drive it for 5-6 days and put about 500-1000 miles on it and all of the warning lights come up again. I have taken the steps with the BBB to start the Lemon Law process. GM sent an engineer out to the dealership to try and figure out what the source of the problem is. The only thing that GM can point a finger at for causing the problem is the fact that it has an after market lift kit installed. They declined the buy-back due to me putting the lift kit on (not surprised). I have arbitration next week to see what a 3rd party will say about the buy-back. I have reached out to BDS to have them create something for me stating that in order to properly install the lift, there is nothing that needs to be done with the brake system. The shop that did the work had to do some light trimming to the wheel wells so that the tires would not rub. I am curious if anyone else has had this issue that may have had the same lift kit installed. Arbitration is next Tuesday so any advice/help would be greatly appreciated.
Thank you all!
i am amazed the dealership has spent as much time as they have. 4 inch lift and 35 inch tires, not an oem size. did you have the truck recalibrated for the tire size. i know you are going to say i went 19k with no problems, but you have a problem now that cant be figured out and you want a buy back on a modified truck. put the truck back to stock and if you still have a problem you might have a leg to stand on. sorry but if i worked for gm and put as much time into it as they have and its not fixed i would wash my hands and walk away also. face facts and find a better shop to fix it, its your problem not gm's
here is the statement from our (BDS) engineering department.
" To whom it may concern,
The BDS suspension lift system BDS1808H - 4 Inch Lift Kit | Adaptive Ride Control Only | Chevy Silverado High Country Or GMC Denali 1500 (19-24) 4WD | Gas does not involve modification or opening of the braking system when installed or during operation. Additionally this system does not modify any programming of computers or modules controlling vehicle functions. This utilization of the factory braking system components would omit cause of brake system failure code issue from being associated with the suspension system. In our experience and testing we have not had any of these trucks with the 4inch or 6inch kits present errors related to the brake system. "
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
