Too cheap for electric ones but ready to admit im going to need something lol. I generally don't like how they look so that being the case do you guys have any input on some that are tucked away? something semi hidden? Probably have to be rocker mounted but thats not the end of the world.
Something along these lines
https://realtruck.com/p/go-rhino-rb20-slim-running-boards/v/gmc/sierra-2500/2024/
The more "hidden" a set of steps are, the less useful they're likely to be for helping get into and out of the truck itself. Also, you may want something that protrudes a touch more simply because you're in the rust belt. My 2015 had steps on it from day one (the wide chrome ones) and the rockers and such were pretty much perfect after 100k of New England driving (road salt and sand in the winter, sand and gravel the rest of the year on the secondary roads).
When I test drove an HD truck before ordering one, I knew I needed running boards to get in and out. My previous 1500's did not need running boards. I liked the look of the high clearance running boards but did not think they were a good fit for getting in and out and read that kicking the truck with boots on getting in would be a problem.
I went with the the GM 6" black running boards and they work out well for myself and my GF for getting in and out.
Edited by rjgvt
I didn’t want them at all but everyone else in my family needed them so that’s that. I’m cheap so I went with best best deal on Amazon with the best reviews and the individual step style which I prefer. These have held up well now through two winters.
in other news, Wisconsin is about to get hit by a blizzard, it’s not in the news but I just did a full spring cleaning of my truck so I know it’s coming haha
  • Haha 1
The stock AT4 boards are pretty tucked away and looked like a good option. I put Bulletproof Bumper running boards on, they are a local company with a terrible website and bad ass products but I am not sure if you can find them in the US.
I have the same Rino RB20's that you linked in your opening post.
No regrets at all. I wanted something that was tucked in close to the body and didn't effect ground clearance, and low profile.
thats exactly what im after. ill gladly give up a little convenience for something that doesnt make the truck look low. good to hear youre happy with them, thats likely what ill get. thanks man
How about a set like these from a 2020
I have some Go Rhino running boards, up a little higher and tucked away.  Nice and solid.
That’s what came on my truck and they work really well as steps, while not hanging excessively low or out. There’s an all black version of those, too. The chrome ones are probably going to be easier to find and less expensive as take-offs because of the current broad preference for all black styling. In ten or even twenty years the chrome ones will still look like new.
I have the all black version of these steps on my truck and can attest (also) to working well as a step and being of a good overall size and position.
The chrome ones will not, however, "still look like new" in any areas of the rust belt. I had the 6" square chrome version on my 2015 and the driver's side step was showing signs of corrosion eating through from the underside after only half a dozen reasonably mild New England winters. Don't get me wrong - I don't expect the all-black ones to fair any better, and actually expect that they'll be worse overall. The reality is that they are made to bare minimum standards and simply won't hold up over time if you're driving anywhere that has to treat the roadways in the winter.
We’ll see how the black ones fair in Vermont winters. I only need them to last long enough until I trade the truck.
Good point. I’m in the Pacific Northwest where we don’t have much salting of the roads.
those look awesome. thats going to be what i do. thanks for the pic man
Did you go with the the bed liner coat or the black powder coat? And did you get the B20 or B30?
Edited by Cal15
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 686 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
