As many of you know, the refresh trucks have big screens for the infotainment system. For some reason, GM has not allowed Carplay to be fullscreen but Android Auto does have fullscreen. The way I got around this is by using a Tbox Plus from Carlinkit. These boxes allow you to not only do stuff like Netflix, Hulu, etc... on your screen, but also have wireless Carplay. These devices come preset to use Apple Carplay as the connection method to the car. This means the screen still won't fit fully. To fix this, you have to change the connection method by putting the attached file onto an sd card (format exFat), put into the Tbox Plus, and a message will pop up asking to change the connection method. Click Yes and it will restart and ask to connect an android auto device. And you are done! It sucks that you have to buy a device to get carplay full screen on these trucks. Fingers crossed GM decides to send an update to make this native.IMG_4077.thumb.jpg.f43e402b07fca4b66a440febb68214be.jpg
reverse.ini
Thanks for the info. Glad you got it working  and as you said hopefully GM will make this native. No reason they cant.
I  am not an iphone user. You said "also have wireless Carplay".  Do iphone users not have wireless carplay to start with like Android users?
My only gripe is you cant pull data from your phone plan so without Onstar you dont have full functionality Something else GM could have easily done
I use a device like this on all 3 trucks. I honestly think this hack is one reason why gm is deleting wired car play from their vehicles.
The vehicle has wireless CarPlay. My main point was the CarPlay aspect. These devices also add wireless CarPlay to vehicles that did not have wireless CarPlay.
Pull data from phone for what? The Tbox? You can connect the tbox to your phone hotspot if that’s what your talking about.
They still have wired CarPlay. They have wired and wireless on the newer trucks. The only way this works is because the box needs to run CarPlay through Android auto for it take use of the full screen. It just so happens that these boxes use wireless CarPlay.
I am talking about in my configuration. There are a few features that don't work without Onstar data. As an example the posted speed limit sign the sales guy touted. Does not work without a data plan.  Normally, I would not care but  I have a heads up display at the posted speed limit sign is quite nice.  This is different over the various years.  I have heard rumors the 2025 will not be the same.
Quote
I use the hotspot on my iphone, and have an automation that runs.  When the phone connects to CarPlay, it turns the hotspot on (and the truck will connect to that wifi hotspot) and then when the phone disconnects from CarPlay, the automation runs to turn off the hotspot. Works great for me and I can use the built in google maps.
That is an interesting concept.  I have Bixby automation routines for other things now. I might have to play with that for fun.  It would have to be automated and quick. My average daily trip is 10 minutes so do not want to mess around connecting to phone, etc just to have functionality.
But that is great food for thought. Thanks!
reverse.ini 236 B · 11 downloads
Which one do I buy as hey all say for Android? Thanks for your help with this, looks great!
I have the one that is (4+64G) model. I believe the difference between the difference between this one and the (8+128G) model is the latter has 8 gigs of RAM with 128 Gigs of storage compared to 4 gigs of RAM and 64 gigs of storage. You should be fine with the (4+64G) model like mine.
Thank you, ordered! Appreciate your research on this.
Good info. Thanks
I’ve tried a few different devices for getting cat play full screen mode, but not the exact device you used.
All of them I’ve tried do technically get it full screen, but each has other issues. One didn’t allow the mic to work with Siri at all. She wouldn’t even read text messages. The other produced a massive echo when making phone calls.
Does this route have any issues?
reverse.ini 236 B · 30 downloads
You are the man ,thanks .. it worked ..
Glad I could help. Some things that are aggravating is when you turn the truck on, the truck auto switches to that sound output, even if nothing is playing. I like FM radio. When I turn my truck on, it plays then it switches sources to the device a few seconds later, so I have to manually change the source back to FM. Also, whenever carplay does output sound (Siri, navigation, etc...) it changes the source to that and doesn't switch back. I know that's a GM issue because my 2019 would change source to carplay and then not change back. If anyone knows a fix for that, that would be awesome.
    tblt44
    tblt44
  • Who's Online   5 Members, 0 Anonymous, 822 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
