Hey guys.  I have a 2024 GMC sierra AT4 3.0 duramax.  When I’m traveling at higher speeds the ride is crazy bouncy.  It’s like driving a basketball down the road.  I thought it was the crappy wrangler tires so I went to the dealer and had them road forced balanced.  3 out of 4 couldn’t be balanced and were replaced under warranty.  I paid for the 4th one thinking well at least it’ll solve my problem.
Replacing and balancing the tires did nothing.  It’s bounces crazy down the road at higher speeds.  It might even be worse with the new tires.  I’m at the point of hating driving this thing.  Anyone else have a bouncy ride and figured out how to fix it?  I have approximately 2500 miles on the truck and it’s been doing it since 0 miles.  I figured well maybe things need to break in, but that doesn’t seem like the case.  Thank you guys in advance.
I know someone who bought the same truck back in 2023 and complained of the same bouncy ride. Could not take so he traded in for an 2024 SLT.  Its the AT4 suspension, its off-road tuned.
Edited by Z45
Do you think installing like the eibach pro truck stage 1 suspension solve the issue or would that be a waste of money and not do a whole lot on a AT4?  I debated trading it in already as well to be honest but I owe way to much on it and just can’t take the hit right now.
I also thought about maybe just throwing a set of bilstein 5100’s just in the rears because it’s cheap and easy, but again I’m not so sure if that’ll do much for my issue.
You have to better describe bouncy.
Does the truck continue up and down motion after hitting a bump, similar to a boat riding up and down waves? No individual impact is noticed.
-OR-
Does the truck hit a bump and experience one harsh hit without continual motion? Every little impact is felt as harsh hits and jars.
Easy things to check:
Tire pressure, no higher than the door sticker.
Easy things to change:
Shock absorbers, there is a bunch of talk about these but you first need to determine what type of suspension motion (spring action) you are trying to adjust.
Edited by asilverblazer
It’s hard to explain and I don’t want to sound TOO dumb, but it’s kind of like a jackhammer type bounce.  Not quite a vibration but many rapid small bounces.  It’s like someone is rapidly dribbling a basketball very closely to the ground.
-OR-
Sorry forgot to hit the quote button on my above reply.  Thank you.
Tire pressure on the door sticker is the 'cold' pressure.
Pressure sensors will show that the pressure quickly increases as the vehicle is drive.
The tire and vehicle manufacturers knew this when they established the 'cold' pressure.
Are the wheels and tires the standard factory 18" wheels or the optional factory 20" ones? (or maybe something else)
'Jiggles' does sound like a vibration that might occur if something is out of balance.
GM dealers (are supposed to) have a scope that can be installed to measure the frequency of the vibration while the vehicle is driven.
Knowing the frequency should make it easier to identify the vibration source.
It has 20” rims with the duratracs.  Adjusting tire psi up and down made no change.  I’m leaning towards suspension.  I know it’s an off road package but damnnnn so bouncy.  It’s almost like the springs and or shocks are overly sensitive.  Almost to the point of making me sick.  Dealer states no lights no problems can’t reproduce operating as normal.  Not wasting my time with those bozos unless a CEL comes on.  I’m wondering if the Eibach stage 2 would clear up the bounce.
It sounds to me like you are describing bumps and imperfections that are too small to compress the springs and subsequently too small for the shock absorbers too have any impact as well.
Your basketball dribbling is a very apt description - what is a tire if nothing vastly different from an air filled rubber ball?
Notice the difference in how a basketballs bounce changes based on the amount of air in it?
If you've lowered the air pressure and can't get the dribbling under control that way, the next suggestion would be to try different tires (and wheels with a smaller diameter).
Despite my comments above a softer shock may help some if the dribbling is sufficient to compress the springs.
Lastly it could be a combination of shocks, tires, wheels are needed to get the ride quality you want.
Thank you.  Air pressure had very little if any noticeable change.  It sounds like it’s going to take some playing around on this one.  Thank you again for the reply.  Have a good day.
Would it be ok to replace the rear shocks only or do you guys think I need to replace the rears and the fronts?  I wanted the bilstein 5160’s but after so much research I’m thinking just going with the 5100’s might be ok.  I don’t plan on off roading and if I did it’d be a slow ride down a cool road, nothing crazy or extreme so I’m thinking the oil chamber might not really benefit me at all.  Am i thinking about this clearly or are there other benefits to the 5160 that I’m not seeing?  My thinking is it’s for heat dissipation when off roading and doesn’t have much to do with additional ride quality right?
The comments from @asilverblazer make sense.  The imperfections in the road aren't enough to the compress the springs so the vibrations are being transmitted into the truck chassis and ultimately into your seat and your body.  It probably has more to do with the stiffer spring rate in the AT4 vs other models and not so much with the shocks.  The shocks just slow down or even out compression and rebound from the springs.  Rather than trying replace the shocks with the hot name brand, I'd take it to a tire and wheel store that also specializes in suspensions and see what they suggest.  Maybe take it to 2-3 places for opinions.
I had ^ this and resolved it with Rancho 9000's set about 7 in the front and 3 in the rear.
I had the dealer install and removed the factory Ranchos at 45,000 miles. It still rides like a truck but only bounces once instead of 3 or 4 times. I have a 2020 Silverado with the Z71 package, Michelin Defender tires installed at about 20,000, original size, from Costco on original 18" rims.
Edited by Joe Drives
spelling
So, you can't feel that bounce at low speed? A neighbor had a similar experience on his 2023 Sierra at around 40-60mph and it went away after installing the new tires from 4Wheelonline plus the alignment.
Edited by xranger90
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
