i am looking for a new new to me truck and wanted to ask for opinions on the new 10 speeds transmissions that come on the 24 up trucks
15 hours ago, Chuck FB said:
The Edge or Banks units, are they compatible with the gas engine as they appear more refined in how they are made as well as rigged up with methods to mount them vs the scan gauge.
I’m not familiar with those units since I’ve always used a scangauge since about 2010 and they have always worked for me.
the sg3 comes with a suction mount that is a magnet which works fine but I simply put a small piece of 3m extreme two sided tape on the bottom and have it nicely sitting up on the dash. No issues and very clean.
8 hours ago, Chuck FB said:
If you decide to install a drain plug into your factory pan, take some photos of it and whatever information if any that you used to decide on the location to install the plug. I expect there would be certain spots or a best location to install it due to not interfering with the trans filter for example or the locations of the magnetic pads. I also presume any of these aftermarket plug install solutions will unfortunately have to stand up a distance inside the pan and takes away from allowing as much fluid to be drained out vs if one had a specialty bung welded into the pan that did not have an internal rise above the bottom interior, or bought an aftermarket pan that fit the limited clearance of the exhaust cross over on the gas trucks.
On my 1500, I bought a second stock pan and had a “bung” welded on a bottom corner. This allowed for a very good drain. In dropping that pan (only once) I used the “ remove the exhaust hangers method” and had plenty of room to work. Not sure how well it would work on the 2500.
That would be the way to do it by having a bung welded on or as was suggested on here as per buying a Dorman pan and I will admit I cringe every time I hear that brand come up but its not a very expensive pan through Rock Auto as long as one is in the states, it would cost many times that if bought in Canada ( for no logical reason ).
Being that your in Florida your exhaust may not have the sort of rust that happens very quickly on a salt covered winter road and the two nuts that join the break point at the rear of the trans might undo easily. Between that and undoing the hanger on the trans you might be able to flex the Y pipe without too much stress to the header flange mount. I don't know if there is a seal or gasket of some sort at the manifolds to Y pipe, as long as it would not ruin a sealing surface perhaps the hardware could be backed off just a bit at the manifolds if need be, again as long as the hardware isn't all seized up.
Your trial will prove good information as to what method will allow the pan to slip out.
It would have to be an aluminum bung which makes it a little more difficult. I am going to buy the Dorman pan.
Edited by bruceb58
Yes that is true as per the aluminum bung and designed for the plug style you want and if you did decide to do that lets say rather than the Dorman pan, one would have to find a shop that has skilled tig aluminum welders on staff. Definitely easier to buy a pan ahead of time and the filter and oil etc so there are no hang ups.
Oil, again your able to purchase that quite reasonably cost wise through Rock Auto as one source and I know from buying oil to have on hand from the dealer here in Canada, they were kind and dropped the price from the normal dealership price when buying it by the full 12 quart case, its not an oil most other parts supply retailers carry up here I found.
Edited by Chuck FB
I know how to TIG and have my own welder. That being said, I would probably get a new pan to put the drain plug on if I did it that way. Better to do a Dorman.
The other option is this pan. Not sure I like how deep it is though for ground clearance issues, although its only 2.7" deeper. https://yourcovers.com/pml-gm-allison-10-speed-10l1000-deep-transmission-pan.html
Edited by bruceb58
Good on you for having the welder and the tig experience, I am severely lacking when it comes to welding and only have a stick welder at my disposal and so seldom weld ( its embarrassing to admit ) and once in a blue moon I do some brazing with ox/ac.
As to that link to the pan, I don't expect that pan will fit on your gas truck and I've not looked just lately at the various companies that make higher volume aftermarket pans but it certainly had been not long ago that they were all for the Duramax because it doesn't have the cross over pipe and so it would have to be an oddball pan made for the gas truck to have a deeper sump if that was sought after. I believe the Dorman pan is a direct factory volume swap that either the diesel or gas can use and my guess is that they made it because they added the drain plug, like the factory should have done in the first place !.
I spoke with them and the flat portion of the pan that is under the exhaust is actually less tight than the stock pan. It should fit easily.
There are measurements on the website that show how far forward the flat part extends so it should be easy to verify.
That's interesting, odd why they only list it for a duramax on the main page if it might have the ability to fit onto the gas version. I know some of these companies that make pans specifically say does not fit the gas truck with the 10L1000
Just now I looked at their application list and they word it rather strangely but you are right that they elude to it fitting on a gas truck that has the 10L1000. Hmm, have them confirm it and send you one and if it does not fit that they take it back on their dime.
Edited by Chuck FB
I will use the measurements to determine that before I buy it. I still might just get the Dorman though.
I had not looked at the price until after my comments, certainly pricey in USD, never mind what horrific price would be attached to something like that up here as the Dorman pan is stupid expensive up here for no good reason.
While more oil is usually better, I do wonder how much of a difference a bit of oil would make to the trans temp.
After being on vacation for a week, I quickly read through the posts.  Can't say I understood everything but in case anyone was interested, here are a few Scangauge x-gauge settings I used on my 24 6.6 gas / 10-speed, 2600 lb. truck camper in bed, using a Scangauge II:
Description   TXD        RXF          RXD  MTH          NAME
Engine Oil
 Temp (°F)    33F122301C C4620530361C 3008 00090005FFD8 EOT
Engine Oil
 Press. (PSI) 33F122A22C C46285A2362C 3008 001D00050000 EOP
Trans. Fluid
 Temp (°F)    33F1227004 C46205703604 3008 00090005FFD8 TFT
Trans. Gear   33F1227053 C46205703653 3008 000100010000 TGR (or GER)
On a trip this week that included hot climbs (e.g., 100*F, 58 east of Bakersfield):
(1) Engine oil temp was well-behaved, briefly hit 221*F a few times.
(2) Engine oil pressure same as on gauge although gauge not as detailed.  I stopped monitoring this on the Scangauge.
(3) Trans temp hit 204*F just one time in the desert, and not on the hottest climb!
(4) I like knowing what gear it's in!
I really wanted a Scangauge to watch the engine temps since the dash gauge sits in one position over quite a range.  I had a 2004.5 LLY which was always pushing temp limits so I'm a little sensitive to engine heat.  Totally under control on this new truck!!  Goes up to 206*F and something happens (fan?) and it cools right down into the 190's*F . . . even on big hot climbs.  I like this truck!!
Engine Oil
Engine Oil
Trans. Fluid
Were you running the air conditioning on the climbs ?. As to the temp ( being that you can actually see the coolant temp the the monitor ) dropping like that, could you detect the sound of the fan howling. I assume if the engine rpm is up a ways that the fan would sound off or at least that has traditionally been the case with fans when they are forced to drive at a much faster speed then they normally do when the clutch is not locked up on it. I am guessing that the engine oil and trans temp dropped some as well when you noted the coolant temp was notably falling ?
So now you just have to head to Death Valley this summer the moment you hear they might have a heat wave like I was told happened the week before I drove through there years back and was 118 when I was there but they had hit 129 the week before ... then drive out of the valley on the long climb in the heat of that hot day with the air con running, now that would be one killer of a test !.
A/C on full blast.  On my old LLY the fan ROARED.  While my hearing kinda sucks, I can't hear or feel this fan . . . I'm assuming it's the fan that causes the engine temp to drop so dramatically.  Engine oil and transmission temps are much slower to respond so, no, they didn't drop directly.  But they also stayed in very normal ranges.  Again, I am impressed!
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
