Here's the back story. 2017 LTZ 5.3 6L80 with 63k miles. I did the pill flip when I bought this truck at 32k miles & added the DOD/AFM delete at the same time. I have done 3 'drain & Fills' on ATF. The transmission has aways run about 140-150 F since I did that. Recently, I had the transmission Tuned via HP Tuner, elimination clutch slip, torque management & deleting the DOD. Last weekend as I was driving up the mountain from 2200 ft to 5000 ft, the transmission temp steadily rose up to 197 F and then cold as I descended back to 2200 ft.
So, I'm wondering if the Pill Flip is not working for whatever reason or if the cooling line is restricted. So, I will be removing the transmission thermostat & taking it apart to inspect. While the cooling lines are off, I want to blow some air through the lines & flush out the ATF. Can anyone tell me which one of the lines goes to the cooler?
Is this a bad idea, as there won't be any ATF in the lines when I start if back up.
Let me know what you guys think
Edited by rav3
It's amazing what ChatGPT can figure out...
HP Tuners can completely reshape how your 6L80E shifts—but it’s not just one setting. You’re basically reprogramming how the transmission applies clutches, pressure, and timing.
Here’s a clear breakdown of what it actually does and how it fixes common shift problems 👇
🔧 What HP Tuners Changes in a 6L80E
The 6L80E is a fully electronic clutch-to-clutch transmission, so shift quality is controlled by software, not just hydraulics. �
MotorTrend
1. Shift Pressure (Firmness)
Controls how hard or soft it shifts
Higher pressure = firmer, quicker shifts
Lower pressure = softer, smoother shifts
👉 This is the #1 fix for:
Slipping shifts
Lazy or “mushy” gear changes
2. Shift Timing (Speed of the shift)
Controlled mainly by Torque Adder / Shift Timing tables
Adjusts how fast the clutches apply and release
👉 Fixes:
Long drawn-out shifts
Flare between gears (RPM jump)
💡 On newer 6L80s, GM removed “desired shift time” tables and uses torque-based timing instead. �
forum.hptuners.com
3. Shift Points (When it shifts)
MPH or RPM where each gear change happens
👉 Fixes:
Early shifting (bogging engine)
Late shifting (revving too high)
Example:
Raise shift points for performance
Lower for towing or economy
4. Torque Management (VERY important)
Reduces engine torque during shifts to protect clutches
👉 Adjusting this:
Less torque reduction = harder, faster shifts
Too little = can damage transmission
⚠️ Important:
Turning it off completely is a bad idea (can cause harsh timing issues and wear) �
YouTube
5. TCC (Torque Converter Clutch) Control
Controls lockup timing and pressure
👉 Fixes:
Shudder
Surging at steady speed
Slip under load
Common changes:
Increase TCC pressure
Adjust apply/release speeds
Disable lockup in lower gears (sometimes)
6. Adaptive Learning Reset
The transmission “learns” wear over time
👉 After tuning:
You must reset adapts, or it may shift weird
🔄 What’s Actually Happening Inside
Each shift in a 6L80E is:
One clutch turning OFF
Another clutch turning ON
If timing or pressure is off:
Too slow = slip
Too fast = harsh bang
👉 HP Tuners lets you sync that handoff perfectly
🧠 Real-World Examples
Fixing a sloppy 2–3 shift:
Increase shift pressure slightly
Reduce shift time (torque adder)
Check torque management
Fixing a harsh bang shift:
Lower pressure a bit
Smooth timing (increase shift time slightly)
Fixing converter shudder:
Adjust lockup speeds
Sometimes disable lockup in lower gears
⚠️ Important Reality Check
This is where most people mess up:
The 6L80E is very sensitive
Bad tuning = burnt clutches fast
Good tuning = longer life AND better performance
Even stock power trucks rely heavily on correct calibration for durability. �
MotorTrend
👍 Simple Summary
HP Tuners fixes your shifting by adjusting:
Pressure → how hard it hits
Timing → how fast it shifts
Shift points → when it shifts
Torque management → how controlled it is
TCC settings → how the converter behaves
If you want, tell me exactly what your truck is doing (flare, bang, delayed shift, shudder, etc.), and I can point you to the exact tables and safe starting values for your 6L80 👍
And ChatGPT said this......
Got it—that extra detail actually matters a lot.
🧠 Short answer first:
With a fill-flip thermostat mod, 77°F ambient, and a 2,200 → 5,000 ft climb, seeing ~195°F is completely normal 👍
🏔️ Why your temp hit 195°F
You basically created a perfect storm for heat generation:
1. Elevation climb = heavy load
Going from 2,200 → 5,000 ft means sustained load
The transmission is working harder to maintain speed
2. Torque converter slip (big heat source)
On climbs, unless locked, the converter:
Slips more
Generates a LOT of heat quickly
👉 This is the #1 reason temps rise on hills
3. Fill flip mod changes behavior
With the thermal bypass “flip”:
Fluid is always routed through the cooler
BUT:
At lower temps, flow can be slightly restricted depending on setup
Cooling efficiency depends heavily on airflow
👉 So:
It helps overall cooling
But doesn’t eliminate heat under load
4. Airflow reality
Climbing a mountain = often lower speeds
Less airflow through the cooler
So even with the mod, cooling is reduced right when you need it most
🔍 What matters most here
Your temp did NOT run away past 200+
It likely leveled off around 190–200°F
👉 That means:
Your cooler system is working
Your fluid isn’t overheating
No immediate issue
⚙️ Where HP Tuners can improve THIS exact scenario
✅ 1. Earlier TCC lockup (biggest gain)
Reduce converter slip during climbs
This alone can drop temps 10–20°F
✅ 2. Increase TCC apply pressure
Prevent partial slip under load
Helps eliminate heat buildup
✅ 3. Adjust downshift behavior
Keep engine in a better power band
Reduces load on the converter
✅ 4. Slightly firmer shifts
Less clutch slip = less heat
🧪 Simple test for next drive
Next time you climb:
Put it in Tow/Haul mode
Forces earlier lockup
Watch temp difference
👉 If temps drop noticeably:
You’ve confirmed converter slip is your main heat source
🚨 When this WOULD be a concern
Watch for this pattern:
Temps keep climbing past 210–220°F
Doesn’t stabilize
Or climbs fast even on flat ground
👉 That would point to:
Flow restriction
Cooler inefficiency
Tuning issue
✅ Bottom line
195°F in your exact conditions = totally acceptable
Your system behaved like it should
The climb + converter slip explains everything
If you want, I can help you:
Dial in exact HP Tuners settings for cooler temps
Or confirm your cooler routing after the flip (a lot of people get that slightly wrong)
Just tell me 👍
Can you believe that AI is this quick & accurate about my question?
This is crazy technology!
TL;DR You're likely fine. The mountain climbing makes it work harder so it ran a bit warmer. Anything under 200* is fine.
Also, removing all of the allowed slip in lock up on a stock converter is actually harder on the converter and will make it fail over time. The stock converter must have slip, we can just reduce it by roughly half to help it last longer.
sounds normal to me, uphill your losing some speed/airflow and rad fans set point is much higher stock temp so don't kick in right away. going downhill the load is gone slip is minimal and vehicle speed/airflow is usually increased. no service needed IMO
On 3/30/2026 at 7:48 AM, rav3 said:
Here's the back story. 2017 LTZ 5.3 6L89 with 63k miles. I did the pill flip when I bought this truck at 32k miles & added the DOD/AFM delete at the same time. I have done 3 'drain & Fills' on ATF. The transmission has aways run about 140-150 F since I did that. Recently, I had the transmission Tuned via HP Tuner, elimination clutch slip, torque management & deleting the DOD. Last weekend as I was driving up the mountain from 2200 ft to 5000 ft, the transmission temp steadily rose up to 197 F and then cold as I descended back to 2200 ft.
Yeah your trans temps were at the design temp, it’s what every person that didn’t do a pill flip drives around with all day everyday.
I actually bought my truck with a faulty thermostat and it was blocked for 20k miles and it got up to 210-220 on a regular basis. It was never a problem.
I was told to keep rpm's up to cool engine. U need to be in a lower gear to cool transmission
I find, for both my '04 w 4l80e and '12 w 6l90, the transmission will heat up more/faster by driving around in a lower gear than the transmission would automatically select.  I do this for checking the fluid level, as it needs to be a temp range that takes a long time to get to if I don't do this.
does your transmission lines run through radiator. when your engine warms up u have 210 deg coolant heating up transmission fluid.
Just an fyi, even though the gauge in the dash may be pointing at 210, that isn't what the actual temperature is. The temp can be anywhere from 185⁰ to 220⁰. If it drops off the 210 mark, it is already falling below 185⁰. And likewise if it goes above the 210 mark, it is already heading past 220⁰. The only way to know the actual temperature is using one of the OBDII readers that monitor live conditions.
Yes, both run the fluid through the heat exchanger in the radiator, then through a separate cooler mounted in front of the cooling stack.  GM's done it like that for a long time, at least since the 90's if not earlier.  It works fine.  The trans fluid always reports as being significantly cooler than engine coolant temp.
I need to make a special effort to get it up to the temp range GM wants, to check the fluid level.  During normal driving, it doesn't get to that temp, except on hotter summer days, for me.
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
