When I open the door there is a sliding sound as if something is opening. When I turn off the engine there are numerous sounds as if the truck is shutting down. Has anyone experienced this? Is this normal?
No CEL, no other issues = normal.
Opening the door, isn't that the fuel pump priming? (that's what I always assumed)
Lot's of crazy clicks and things after I kill it. Relays? Underpants gnomes? (iykyk)
14 minutes ago, Dennis1947 said:
2026 1500 RST Z71, 5.3 engine
See above, 2025, 1500 LT, 5.3.
Various noises. Especially when new.
Opening any door primes the fuel pump. And when turning off the vehicle there's all sorts of modules that go to sleep at various times and make all sorts of noises. Totally normal.
Edited by Atomicgrl
All normal.  Every bit of it.
Thank you for bringing these noise concerns to our attention, Dennis. If you are unsure what might be causing these sounds when you shut your truck off, we recommend taking this to your dealership for further evaluation. Our team would gladly take part in this process alongside you and your dealership to ensure these noises are not something more serious. Please fill our our support form https://s.chevy.com/support-request so we can look into this together.
