transmission heating up
hi there i have a silverado 2500HD 2002 i just got my transmission fixed and its working fine but just after fixing it the transmission temp just wont get down i checked everey thing the transmission oil level was good and the transmission cooler is cleane and not stuck is there any thing may do transmission heating go up that much or dose it have to be re programed
I'd check the cooling lines all the way up to the radiator and back. Maybe someone kinked or mashed one of them when they were working on it.
How hot is it getting?
Mine runs in the 150*+ range in the summer, and I've seen it over 200* when towing. This is in my 6.0L HD with the 4L80E.
over over heating over 250 and getting some time a messege in the messege center that my trans flud is hot in yello and getting another messege that to idle engen in red when it got over 275
i did go to my dealer in kuwait he don't know any thing he just said that i have to keep my truck and he will see it next week lol :seeya:
please any good idea :chevy:
While, or before even, you're changing your cooler, pull one of the lines and see if it's flowing any fluid through there.
You said you just got it fixed. What did you do or have done? When we got our dog fixed, it took a week or so for her to come back around to normal... Maybe you should wait a while? :happysad:
you need to pull the return line off the radiator you need to have 1 qt of oil in 20 seconds any less and it will overheat
im gona change that cooler the one in the raditor i have a feeling that some thing stuck inside but i will do you're idea before i change it but what do you mean by 1 qt of oil ?
1 qt of tranny fluid in 20 sec if you have that then theres no need to change the cooler
