07 08 Nbs Owners...
  • Replies 224
BTW...Count'em Jeff.....SIX wrenches :lol:
You bastard!!!! :lol:
Hey...Thanks!! I try :uhoh:
Yeah, but look how long it's taken you to get 6 wrenches.....slacker!!!! :crackup:
Orange peel is a ripple in the clear coat which results in a dull finish in the paint.
Orange peel is the result of an applied coat of paint (basecoat, clearcoat, or both) that doesn't flow out or level fully. Keeping in mind that paint is basically applied as a liquified plastic, the cause of peel is that the paint either doesn't stay liquid long enough to completely flow or the material is to viscous to allow it to flow out. In either case, the paint ceases to flow before the surface is completely level. The result of this is a lumpy orlopey surface that resembles the peel of an orange, hence "orange peel. So, to eliminiate this problem, you lower the viscosity or simply keep the paint liquid longer, right? This may not be a s easy as it seems. Solvent-borne paints are categorized by the ratio of paint solids (resins, pigments, binders, etc.) to liquids (solvents).
yeah, good explanation, but it still doesn't explain to me how you can eliminate it with wet sanding when the non-uniformity (depth of the "peel", or the height of the bumps...you get the idea) is greater than the thickness of the clear coat. Still seems like trying to sand a hill without removing the grass. :uhoh:
Not saying you guys are wrong as I am no paint expert, I am just not understanding it???
Once you start sanding you can tell how much you need to do, the low spots will be a different color so you keep sanding until they are gone, or until it looks good. remembering not to cut thru the clear in to the base coat..... then once you buff it it will smooth out and fill in all the hills and valley's that is what compounds are for. as soon as i find a pic i will post it kinda hard to explain......
but if it was factory paint i would not wet sand because that stuff really isn't that thick, as you can tell from this thread....
But if someone or yourself painted it you know how much is there, plus to do it right you put on a coat of clear, wet sand, put on another coat then wet sand again, repeating until you have all the coats on you want.....
You bastard!!!! :crackup:
Yeah, but look how long it's taken you to get 6 wrenches.....slacker!!!! :rollin:
Hey,I have a life you know :lol:
Some of us have those :rollin:
How about 2GCFK13YX81140178.
Thanks.
Yep,Your involved.
BTW...Count'em Jeff.....SIX wrenches :crackup:
You bastard!!!! :rollin:
Hey...Thanks!! I try :lol:
Some of us have those :fume:
Really? What is this thing you call a "life" and where do I get one? Are they expensive? :uhoh:
BTW...Count'em Jeff.....SIX wrenches :rollin:
Yeah, but look how long it's taken you to get 6 wrenches.....slacker!!!! :fume:
Hey,I have a life you know :crackup:
Some of us have those :lol:
Trust me....You don't want one :lol:
Here hope fully this explains it better for ya Color sanding
That oughta' help Jeff...Well on second thought I don't know if anything can help Jeff :uhoh:
Well that is all i have, i can't explain it any more to him with out showing him first hand. but i did find out what happend to him though
HA HA HA
HA HA HA
:uhoh::lol::lol: The slingshot to the forehead of the sleeping guy made me LMFAO!!! :crackup::rollin::rollin:
I would love to do that to Daddy and/or Scott (AlaskaLTZ). :fume:
HA HA HA
LOL thought ya was talking about me at first
How about 6 wrenches??? :lol:
The way your going,and since you don't have a life,you'll have 6 by the end of the month :lol:
Can someone tell me if 8Z127084 is in this.
Thanks Walt
Yep,It is.
Thank you for looking. It has alot of orange peel but I dont know that I wqill worry about it right now.
