07 08 Nbs Owners...
I would appreciate it if you could run mine.
1GKFK63828J117176
Thanks!
Yep,Yours is listed Bish.
You even have this one listed also...
FRONT FASCIA PAINT CONCERNS. REF TSB 07-08-62-004A
Service Information
Document ID: 2048420
#07-08-62-004A: EI07094 - Front Fascia Paint Concerns on Peeling and/or Scratches (Engineering Information) - (Jan 10, 2008)
Subject: EI07094 -- Front Fascia Paint Concerns on Peeling and/or Scratches (Engineering Information)
Models: 2007-2008 Cadillac Escalade, Escalade ESV, Escalade EXT
2007-2008 Chevrolet Avalanche, Suburban, Tahoe
2007-2008 GMC Yukon, Yukon Denali, Yukon Denali XL, Yukon XL
Attention: Proceed with this bulletin ONLY if the customer has commented about this concern AND the EI number is listed in GMVIS, otherwise disregard the bulletin and proceed with diagnostics found in the published service information. THIS IS NOT A RECALL. Refer to Service Bulletin 04-00-89-053A for more detail on the use of engineering information bulletins.
This bulletin is being revised to add the 2008 model year. Please discard Corporate Bulletin Number 07-08-62-004 (Section 08 -- Body & Accessories).
Condition
Some customers may comment on front fascia paint concerns on peeling and/or scratches.
What Action to Take
GM Engineering is attempting to determine the root cause of the above condition. GM Engineering has a need to obtain information first hand during diagnosis and BEFORE repair. As a result, this information will be used by engineering to "root cause" the customer’s concern and develop/validate a field fix.
Instructions
If a vehicle is encountered with the above concern, please do the following steps:
Record the VIN.
Record the vehicle build date.
Record the mileage at the time of service.
Record the vehicle paint code and color.
Photograph the paint concern.
E-mail the pictures to xxx.xxxx.xxx
Contact Wayne Witkop at the GM Exterior Group prior to performing any paint repair to the front fascia.
Engineer Contact Information
GM Engineering may visit dealerships that are near Detroit, Michigan. In either case you will receive a response back within 2 hours on what action to take the same day of your call (Eastern Daylight Time).
If you do not receive a response from engineering, then proceed to repair the vehicle.
Parts Information
If necessary, GM may make arrangements to have the old fascia shipped to the Warranty Parts Center (WPC) based upon the information provided.
Important: Do NOT ship any parts to the WPC without a WPC request having been issued. WPC Requests will be sent for any parts that engineering wants to have returned.
Warranty Information
For vehicles repaired under engineering direction, choose the appropriate labor operation that best describes the repair:
Labor Operation
Description
Labor Time
A9915*
Fascia, Front Bumper-Color/Clear Coat-One Piece
2.3 hrs
A9914*
Fascia, Front Bumper-Refinish/Clear Coat-One Piece
3.2 hrs
B9821*
Fascia, Front Bumper-One Piece - Replace
1.2 hrs
*This labor operation number is for bulletin use only. This labor operation will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
  • Replies 224
1GKFK63828J117176
Thanks!
by the way, you also have the EI08183:
gmLogoFlat.gif Service Information
2008 Chevrolet Avalanche - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 2138349 #08-07-30-024: EI08183 - 6L50, 6L80, 6L90 RWD Leak From Transmission Oil Pan or Oil Pan Gasket (Engineering Information) - (May 19, 2008)
Subject:EI08183 - 6L50, 6L80, 6L90 RWD Leak from Transmission Oil Pan or Oil Pan Gasket (Engineering Information)
<div align="left">Models:2008-2009 Cadillac CTS, Escalade, Escalade EXT, Escalade ESV, SRX, STS, XLR
2008-2009 Chevrolet Avalanche, Corvette, Silverado, Suburban, Tahoe
2008-2009 GMC Sierra, Yukon, Yukon Denali, Yukon XL
2008-2009 HUMMER H2
2008-2009 Pontiac G8
with 6L50, 6L80 or 6L90 Automatic Transmission (RPOs MYB, MYC or MYD)
Attention: Proceed with this bulletin ONLY if the customer has commented about this concern AND the EI number is listed in GMVIS. If the customer has not commented about this condition or the EI does not show in GMVIS, disregard the bulletin and proceed with diagnostics found in published service information. THIS IS NOT A RECALL - refer to Service Bulletin 04-00-89-053B for more details on the use of Engineering Information bulletins.
Condition
Some customers may comment on a leak from the transmission.
Correction
Important: This bulletin ONLY applies to vehicles equipped with Transmissions 6L50, 6L80 or 6L90 (RPOs MYB, MYC, or MYD). For vehicles equipped with transmissions other than these, DO NOT proceed with this bulletin - diagnose and repair according to information found in SI.
If determined through diagnosis that the leak is coming from the transmission oil pan or oil pan gasket, complete the following steps:
  1. Use the J-42220 Leak Detection Lamp and the J-28431-6 Leak Dye Kit to isolate the leak point.
  2. If a leaking transmission oil pan or oil pan gasket is found, contact either of the following engineers BEFORE any repairs are made:
Technician Name
Dealership Name and Dealership Phone Number
Complete VIN and Repair Order Number
Important: If you do not receive a call back within one hour, proceed with repairs to the transmission.
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
K9519*
Transmission Oil Leak -- Engineering Information
G8
0.8 hr
CTS, SRX, STS, XLR, Corvette
1.2 hrs
Fullsize Truck/Utilities, H2
1.4 hrs
* This labor operation number is for bulletin use only. This number will not be published in the Labor Time Guide.
999999994.gif WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
</div> © 2008 General Motors Corporation. All rights reserved.
Any chance you could check mine?
2GTEK13Y771682607
Thx.
2GTEK13Y771682607
Thx.
Yours is not included, looks like it has been for the 2008 YM
Yes,Its only for the '08 model-year,so if you have an '07 its not involved/included in the bulletin.
3GTEK13M98G113392
Can someone check this for me? I have an 08 with pretty bad orange peel.
Yep,Your VIN is involved.
3GTEK13M98G113392
You are included as well
3GTEK13M98G113392
wow, you are getting faster at those posting skills
3GTEK13M98G113392
I'd be faster if I was at home on my laptop,The internet connection here at work sucks! :uhoh:
3GTEK13M98G113392
I am about to go to work (where there is no access to GM-Trucks.com), so at least you have it at work, I wont be able to get back on until tonight....:lol:
Speaking of work.....I better do some :uhoh:
12:00 o'clock and your just going in?!?
You must have bankers hours :uhoh:
    • Follows the motif on the Sierra EV.  Satin finsh to the lower bumper area, painted above:   Elevation       Denali
    • Not exactly what I was hoping for, but I do like it. I wonder if they'll bring back Smokey Quartz Metallic? 🤔 https://gmauthority.com/blog/2026/06/here-is-the-all-new-2027-gmc-sierra-1500/
    • Whoever greenlighted the work truck matte black front bumpers on every trim but the AT4X should be fired!  I was hoping that was an AI mistake, but just realized they were on every model of the 2027 Silverado too.     Some parts of the interior do look premium, but the Denali Ultimate dashboard looks like an afterthought.  At least they appear to have lost the microfiber the high end Silverado models showed, but the '27 High Country dash looks better than the Denali.
    • New member here. I am researching a read-first event-recorder concept for late-model GM V8 trucks. This is not a sales post. There is no product link, price, preorder, or mailing list. I am trying to determine whether the underlying problem is real before building anything.   Has your truck ever had a brief problem such as: - rough running or a momentary misfire - an oil-pressure warning or unusual pressure event - reduced power or a brief stall - a U-code or lost-communication problem - a symptom that disappeared before the dealer or independent shop could reproduce it   If so, I would appreciate the following details: - year, model, engine, and mileage - what happened and under what conditions - whether a DTC and useful freeze-frame data were stored - whether the shop was able to reproduce it - what the eventual confirmed repair was, if known - what additional information would have helped the diagnosis   The concept being evaluated is a removable leave-in recorder that continuously retains a rolling window from before and after an event. It would not tune, reflash, clear codes, or change the vehicle calibration.   I am also not claiming that it could predict lifter failure or see every internal ECM variable.   The real question is whether continuous event history would add enough useful evidence beyond freeze frame, GDS2, and existing scan tools — or whether it would simply be another unnecessary gadget.   For owners and technicians, which problem would make something like this genuinely useful: 1. intermittent misfire or AFM/DFM-related behavior 2. oil-pressure events 3. lost communication or electrical faults 4. none of the above Please be blunt. Negative feedback is just as useful as positive feedback.
    • No tears over the SLE and SLT trim levels disappearing but I kind of loathe the "Elevation" name. It's a truck--skip the elegance.   The slab-dashboard design is decidedly different. Almost has a Hummer flavor to it. "Professional Grade" seems to be leaning very white-collar, tech-driven these days moreso than blue-collar, functional design.   The Silverado would be my choice between the two new trucks. Pleased with the engine lineup in both. The GMC is a little "too much" for a truck, IMO, and the Denali borders on ridiculous - but I do know there are buyers for luxury trucks out there. It's just not my speed.
