Mickey Thompson Atz's
cev103
  • Replies 35
White letters out!!!
Yeah, and then get a big-ass sticker for every other aftermarket branded item you put on your truck. i.e. Valvoline, Trico wiper blades, Turtle Wax, etc...oh and don't forget the Kleen-Ex sticker for that box of tissues you have in the cab either. You wouldn't want to miss out on any of the free advertising for any of the companies you purchased from. :thumbs:
Although im not a fan of white letters on any tires... for you 'RWL' folks... do you really think white letters would look good on the ATZs????
I don't think white letters belong anywhere on these tires... half of the sidewall is taken up by the tread lugs already
Yeah, and then get a big-ass sticker for every other aftermarket branded item you put on your truck. i.e. Valvoline, Trico wiper blades, Turtle Wax, etc...oh and don't forget the Kleen-Ex sticker for that box of tissues you have in the cab either. You wouldn't want to miss out on any of the free advertising for any of the companies you purchased from. :dunno:
I know the letters aren't white, but it sure looks like a whole lot of free advertising on these tires :thumbs:
Yeah, and then get a big-ass sticker for every other aftermarket branded item you put on your truck. i.e. Valvoline, Trico wiper blades, Turtle Wax, etc...oh and don't forget the Kleen-Ex sticker for that box of tissues you have in the cab either. You wouldn't want to miss out on any of the free advertising for any of the companies you purchased from. :idiot:
I know the letters aren't white, but it sure looks like a whole lot of free advertising on these tires :dunno:
Don't really have much choice here though do I? :thumbs:
+1
I ended up going white out....I didn't really make up my mind until I got to the dealership and saw another truck being worked on which had the white out. I'm very happy with the ATZ's, they fill the void in the wheel wells caused by the leveling kit. I'll take some pics after it stops raining.
+1
+1 perfect the way it is
I forgot the ATZ's had the white lettering, mine didnt have it on there but I wouldnt have had it out, I like the way it looks with the black here is a couple pics
Guess I should read the whole thing I didnt and I didnt realize you already had them mounted out, Id like to see pics when ya get em
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
