Is your GMT-900 using oil
1,555 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey, my 2007 Sierra 5.3 AFM with 90,000 miles has already had a tray put in the oil pan, engine flushed, new spark plugs and wires, and as we speak, having new rings and pistons installed. The service mechanic in the beginning said everything they were going to do to my truck wouldn't fix the problem. He said the only fix would be to install a new engine (which will be the next step on my truck). Apparently the dealership has replaced alot of motors according to the service mechanic. I should get my truck back later this week.
Thanks
Nick
Another oil-burner here with an update. 2009 5.3L AFM. I was burning 1 to 1.5 Q every 1500 miles. Did the oil pan baffle, PCV valve, and piston cleaning fix, still burned oil. Just got it back from the dealer after replacing all pistons/rings and lifters.
I hadn't heard anything like the post above about replacing the engines. Does anyone have an update after piston replacement? Whether it stopped using oil or not? If not, is engine replacement really the next fix?
I'd like to see how my truck runs for awhile, but eventually I'm getting the BB tune and removing AFM.
KCT
Edited by KCTiger
Thanks
Nick
My truck was used 2 quarts in 1900 miles!
Edited by Chipp4242
Well, I went and picked up my truck today after the dealership replacing the rings and pistons. I drove it about a quarter of a mile total and everything was fine until I stopped to get gas. I turned the engine off to fill up and when I went to restart it there was a loud pecking noise and a bad vibration through out the truck. The engine light was flashing. I called the service mechanic and he told me to bring it back. When I pulled out of the gas station my truck was shaking and then when the transmission shifted, it jerked really hard. I got back to the dealership and the mechanic said he didn't know what was wrong with it but he would definitely fix the problem. They have had my truck since last Tuesday.
Thanks
Nick
Edited by Chipp4242
I have been driving under an oil consumption test since GM did my last oil change. Today the "Add Oil" msg came up after 4000kms. Took it in, and on the spot, the service guy was like "yup, no good, Can you leave it here for 4 hrs?" and explained the bulletin about the valve covers and the AFM deflector, etc. etc. Anyway, it also involves cleaning the cylinders and rings? No charge. So I guess we'll see what happens.
Does someone have a copy of this Bulletin? So I can read in detail what they are doing before I go pick it up in a few hours?? Thanks...
Oh and I should mention... its the 5.3L w/AFM, and 95,000kms on the clock. AND as an added plus, I'll plug the dealership (Murray GM in Abbotsford, BC) since they have been very helpful in dealing with all of this with no grief. Gave me a coffee and a muffin while I waited, and then drove me home and will pick me up.
UPDATE from this last post.
Now at 99,656 kms. Since the first step in the warranty repair (the drivers side valve cover replacement at 95,424km) it's going in tomorrow, they're going to drop the oil pan and fix/install something to "fix" this. So here's where we're at:
80,100km Oil change, level now at full.
83,666km Add oil warning
86,470km Oil change
89,192km Add oil warning
91,655km Taken to GM for oil change, and reported problem. Start Oil Consumption Test.
95,424km Add oil warning. GM replaces drivers side rocker cover TSB #10-06-01-008C.
99,656km Add oil warning. GM performs service with 'oil pan deflector' (will have more details once I get the TSB tomorrow when they actually DO the service)
And the saga continues.....
Picked up the truck.... there's a new TSB on this. (Yes, again.) 10-06-01-008D which was issued on January 17, 2012.
Anyway, this time they dropped the front diff, dropped the oil pan, and installed a "bell housing" thing on top of a tube that sprays oil within the oil pan. Kinda like an umbrella.. the tube points up, and this steel 'umbrella' goes on top, and keeps the oil from spraying up, redirecting it down. He showed me the pictures that were on the TSB, it makes alot more sense than I can describe it. Anyway, they also cleaned all the pistons and rings.
So here we go lets see if THIS works.
The service at this dealer has been second to none. No hassles, super friendly.
Well update so far... 2500km and not a drop of oil lost so far.... knock on wood...
  • 3 weeks later...
2008 Silverado 5.3L -
Lifter Broke around 70K - Resulted in New Lifter, New Cam Shaft and Deflector Shield in Oil Pan
80K - New Valve Cover and PCB, Cleaning Solution in Cylinders
86K - New Pistions, Rings, and I don't know what else....It is still in shop (Over 3 Weeks)
It has been consistent - 2 1/2 to 3 qt every 2500 miles
This last time they found lots of oil in the intake manifold.
Seems like they always over fill it on dip stick....this time I am going to make them explain the oil level on the dip stick.
Dealer has been great (slow but great). They give a loaner truck everytime....but after this much time in shop I am not sure I will remember what my truck even looks like!
They just installed the oil deflector in mine. I pick it up today.
Has this ever solved the oil consumption problem on any ones truck? I am thinking it is just the first step. We shall see.
i had that done on mine last year (deflector and flush) worked for a little while and now i just made an appointment today to get the truck back in for consumption again. i drop her off tomorrow.
86,470km Oil change
86,470km Oil change
Continues...
103,976 Add oil warning. GM now says will replace pistons and rings.
Edited by mc7719
Yesterday was my 1st one thousand mile oil level check after having the ring cleaning solution poured in and the oil pan deflector installed.
My truck used a half quart in 1,000 miles. They told me to drive it another 1,000 miles then bring it back to be checked again.
Continues...
So Day 1 of it being in the shop. I was nervous to say the least, dropping her off for open-heart surgery lol. On the plus side, again this dealership (Murray GM in Abbotsford, BC) has consistently provided amazing service and no hassles. I mean, its not THIER fault that the AFM engines are burning so much oil.
They even provided me with a 2011 Silverado to drive for three days while its being fixed!
Fingers crossed. After the piston and rings replacement, has anyone had improvements??
Continues...
I had my pistons and rings replaced just over 5000 miles ago...I burned 1/2 quart at about 4000 miles..then I changed the oil and I haven't used any in the last 1600 miles..I'm not sure if it just took a few thousand miles for the rings to seat or not. All is good for now...In any case the ring and piston change has made a huge improvement..
Continues...
This is good news.
Got my Sierra back from them. Running like a dream so far.
i just picked mine up on tuesday after having the pistons rings and lifters replaced (all under warranty and at 89k miles). so far i have put a little over 300 miles on the truck so far and it feels great. time shall tell if the "fix" worked.
    Smitty462
    Smitty462
  • Who's Online   5 Members, 1 Anonymous, 654 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
