Hey also I'm trying to color match my chrome bumpers and trim around the grille white, any ideas on what I can do without powder coating or plastidip? I don't mind painting them myself, I just don't know much about preperation or how to go about doing it at all. Any tips?
Heres my ride its black w/purple metal flake and red accents.
Edited by BruceDeuce
Well, having seen all the awesome trucks here, here's mine. Just a few teaser pics, more in my gallery and still a work in progress.
2011 Hennessey Silverado 1500 4x4 Crew Cab LTZ Supercharged 6.2 liter 6 speed automatic w/3.42 gears
Lowered with Macgaughys 4/7 with rear air bags for towing
Blacked out front grille and rear bumper
Escalade steering wheel, tahoe cup holder with custom switch panel and sierra denali armrest
Autometer gauge cluster in middle of dash
Drilled and slotted 4 wheel discs with red painted calipers and ceramic pads
Peragon bed cover
Black bezel headlamps with HID bulbs
LED rear taillamps with black bezel
Gm factory side cab, rear bed and bumper valance skirts
Foose wheels 9.5x22 with Goodyear Fortera LS 285/45R/22 tires all around
Chassis mounted air compressor with accessory hose on rear bumper and power plug for winch or booster cables
Dual black stainless steel rear exhaust tips behind rear tires
15% tint on front windows to match factory rear window tints
Damn that is one sexy truck.
Hey guys I got to put on my new grill and headlights, so here it is!
Edited by PETARO
Did the GoodGuys Heartland Nationals yesterday, 4300+ registered cars. Pretty cool.
Edited by SILVERADOSC540
Went down to beach today watched wicked lighting storm
2005 Chevy 2500HD, 6.0l, 4x4, LS EXT cab
MODS
- Cherrybomb Muffler
- Torsions Cranked
-Painted Bowtie
FUTURE
- All Terrain BFGs
- Tinted windows
- Head and Tail lights
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
