At the airport.
Just landed!
1920 Model T and my 2015. The T has been in the same family since new.
  • Like 4
I shared this elsewhere at the forum..
good spot for it here.
3trucks1
my dads new rig.
not just the 2016 pete.. :)
my old one is off to the left.
I use a Sony SLT a35.
not to be confused for a gmc trim package.
Edited by barry G
My cheap rig till I get my Colorado Duramax. The 4Runner is gone. a4643a9f3525e9c940abc75bba090bcb.jpg
Edited by 4.8guy
Nice. If you don't mind me asking, how much did your Colorado cost? I'm looking at purchasing one myself in the next couple months. I was pretty disappointed it didn't get the new 8speed but the Duramax work van got it.
I haven't got her yet. I'm waiting on a new job to start in the spring which will allow me to buy a Trail Boss Edition. It's going rate is about 42K. About the cost of a Silverado but I don't need a full size truck. And I want a diesel.
Oh ok. I've seen some used ones in my area with 3,000 miles listed for about $33-37k depending on options. I've been reading about guys getting high 30' to low 40's with a twin turbo kit. So it's making me debate a used Colorado or a used 525d for my next commuter car.
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
