Hopefully I’m doing this correct:
ok 2015 GMC SLE crew cab 4x4
35-12.5-20s RBP m/t tires
6” mcgaughy lift
airlift rear heavy duty airbags
volant cold air induction
dualled out flowmaster super10 series exhaust
4.5” black powder coated tips
whats next: larger jet throttlebody and spacer
dual battery charging system
just ordered 26” BAP off-road led bar for behind grill
then I’ll be researching superchargers lol
6” mcgaughy lift
look's good
New member, not great pics but here's my 2017 Silverado 1500LTZ Redline w/ 6.2L. Traded in my 2015 Corvette, we'll keep this when the new C8's come out. Replaced the center caps with all black, looking for a good source for Black 14.5mmX1.5 22mm lug nuts to replace the chrome ones on the truck. Appreciate inputs!
Silverado3.thumb.jpg.1c929e43b7af4286874b50143f553386.jpgSilverado2.thumb.jpg.87dd0b3a28780419dcd3095d9fccbb2e.jpg
2015 Chevy 1500 stock height for now. Has window tints, black bow tie, took off some chrome door moldings. Has 20×10×-19 ballistic tanks with 33×12 1/2 mud tires. Sorry I can't figure out how to get pictures to the correct size.
Here's my stock ride. Got it used with about 40k on it. Putting Nitto Terra Grappler G2's on it this Friday. Not going much bigger than stock as I drive it a lot since I'm a real estate agent and care somewhat about MPG haha.
Here's some shots of my 2017 Silverado right after tint and installing Belltech 2-3" drop shackle kit...
8 hours ago, HammerHead0313 said:
2017 GMC 2500 HD L96 6.0 4X4, 100% Stock, Base Model, Drove it off the fleet lot with 6 miles on it. Love it!
I thought my Crew cab & 6'6 box 1500 with tow package was a long truck...man that thing is a monster!
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
