Can I join this club with a new to me 2007 Yukon XL Denali? “Upgrading” from the old faithful 2003 5.3L Yukon XL, and I’ll be having lots of questions about all this new fangled technology I’ve got myself into.
Your Yukon does not have an L9H 6.2 which this topic is specifically geared towards.
Yours has the L94
http://gmauthority.com/blog/gm/gm-engines/l94/
Ryan B.
Hi guys I’m new here as I just recently bought a Sierra 6.2. Now as I do not have a baseline to compare it to, id like to get your insight on this: Idle sound. (I will attached a video of Idle, I sort of hear a scraping sound in the beginning, just me?) if anyone gets a chance, give it a play and tell me what you think. Normal? Not normal? And if you want to show off :P, attach a sound of your 6.2 for comparisons sake. Thanks so much guys!
B4B09F72-0077-4C77-8128-F05121E8351A.MOV
Edited by SinisterWhales
Biggest file I could upload
that sheeeeeeungg sound is normal.  Sounds more like the starter disengaging.  Congrats on the new truck as well.
Ohhh, ok. Thanks for the quick reply and the congratulations(it really is a beast of a truck). Here is a longer audio clip, if you guys can access it. Thanks
sierra.m4a
I have a 2011 Silverado 6.2L with nht and when I asked the dealer about front end and rear end and transfer case fluid change they said front and rear use part # 88900401 and transfer case uses auto trac fluid part # 88900402. Does this sound right?
Really late reply but it is a 75w90 gear oil and i recommend the Amsoil...but I am biased:)
L9H with a TVS 2300 supercharger. :devil:
Hey guys, new to the forum and dont know much about vehicles so bear with me. I bought a 2013 chevy silverado 1500 6.2L about a year ago. E85 is abundant and cheap where i am from so 90% of the time i run E85, unless im in the middle of nowhere and the local gas station doesnt have it.Truck is leveled and my average mpg on e85 is 12.75, but will run 14-14.5mpg on highway. Tires are starting to go bad and i plan to go to a 265/70 r18 tire, a little bigger than the 265/65 r18 stock tire. i am going to get a tuner to calibrate the bigger tires so speedo and odometer are correct. My question is are there any e85 tuners/tunes out there? i have been researching but cant seem to find anyone talking about a tuner you can plug in for e85. Any help would be appreciated!
Your truck is comparable with E85 what do you want to tune it for? General performance? My 2010 runs almost exclusively on E85. Have it tuned (not related to the fuel type) by blackbear performance
Ryan B.
Yes sir, General performance. Maybe something that could increase mpg
Edited by Meado19
I purchased a 2013 Sierra with the 6.2L used from a dealership. the previous owner has installed an unknown tuner to the vehicle. I am trying to install another tuner but it says it needs to be returned to stock before it will install.
How do I return it to stock settings?
I can be flashed back to stock by the dealer. Worst case.
  • 3 months later...
Picked up a Denali 6.2L last night. Love the power compared to the 5.3 but def needs more power to be close to the smile my Dmax gave me. Tons of good info on here for sure!
:thumbs:Its been 8yrs and still loving my 6.2
9 yrs for me
Ryan B.
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   4 Members, 1 Anonymous, 4,881 Guests (See full list)
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
