Ready to get new Silverado - but stuck between a 6.2L and an Ecoboost
Ford spark plugs blowing out is a common problem with Triton engines in Ford F150 pick up trucks, Mustangs, Crown Victorias, Vans, Expeditions and motor homes made before 2004. A video showing spark repair inserts being installed can be viewed on the Calvan specialty tool description page, read on for more information. Ford 4.6, 5.4 and 6.8 modular engines are prone to spark plugs being blown out of the cylinders due to the aluminum threads failing. When the threads are about to come loose there is often a slight ticking noise, like a small "exhaust manifold leak" would sound. When the spark plug threads fail, it can eject the spark plug and break the ignition coil on the "coil over spark plug" design. Although rare, it is possible an engine compartment fire can start due to the raw fuel escaping the engine cylinder and the broken coil dangling, providing the spark. The cause of failure of the spark plug threads can be debated; poor design, over-torqueing, under-tightening can allow the spark plug to vibrate and wear threads while held in by the coil, until the the threads deteriorate and fail. Ford does not recommend repairing the threads, only replacing the cylinder head. The expense involved unless the vehicle is still under an aftermarket warranty can run into the thousands of dollars.
Looked at a calendar lately?
Want me to Google "Silverado problems" and post the pages of links?
  • Replies 52
Really? Quit arguing, let it go
Ryan
OP: Does that camper weigh in at 5000 lbs loaded and ready to roll? If so, that should be an easy pull for a 5.3, and the Ford 5.0 should be a bit better with higher torque/hp. I'm towing closer to 7000 lbs with truck in sig, and the 6-spd should be a bit better for towing. I don't win any races, but I've only seen the kind of trouble you mention when crossing TX in constant 30 to 40 mph head/cross winds. I had to slow to 50 to hold 3rd, but... believe me... 50 was fast enough in those winds!
Regardless, you need to go with what fits you best. I recently test drove an EB crew F150, and had mixed feelings about it. If I were buying soon, I'd have to test drive one a few more times... but mostly because the seating is more roomy for a family. I much prefer the look/ride/handling and build of the GM twins, and would probably lean towards another 5.3 or just jump straight to a 2500HD if I were towing more often.
Edit: There's no doubt that either the 6.2 or EB would pull your camper better than a 5.3... but I just wanted to point out that you may have an "underperforming" 5.3 on your hands, if it's running that hard w/ 5000 lbs in tow. You may want to try out a newer 5.3 and see how it feels in comparison, since you'll definitely have better daily mpg (at least as good as the EB or 5.0).
Get the F150 with the 5.0L. It will give you the best FE overall (towing and unloaded) and it will pull 5K lbs with ease. If you HAVE to have more, get the 6.2L in the F150.
Yea, good luck going that route if you enjoy paying through the nose for a Platinum, Harley or Lariat just to be able to get 6.2L
My uncle owns 2 brand new eco boosts in his fleet. He is getting 17mpg highway with them not towing which I feel is unacceptable since I can do that in my 5.3 for much less money. Towing would just be aweful milage i'd say. I test drove the EB and did not like the way it ran. Yes it's pretty quick when you put it to the floor, however I don't drive trucks with the peddle to the floor on a regular basis, and I feel you need V8 torque to pull a trailer adequately. My dad has a 10 f150 still with the 5.4 and 6 speed, and the tranny shifts very funny, but the rear cab room is awesome! I am not brand loyal in the slightest bit and have owned every brand of domestic full size trucks up to my current 2011 chevy. If I were to buy a new truck tomorrow, it would be a close match between the 6.2 chevy and 5.0 ford. I'd say ford for the cab and gas milage, chevy for the nicest all around truck with tons of power and a much smoother ride. I know this doesn't help a ton, but forget the eco boost if you tow. I love my 5.3 CC silvy, but i will always welcome more power.
If for some reason you decided against the GM Trucks I would definitely go with Fords 5.0 instead of the Eco-Boost. Neither one looks like it would be fun to do a simple oil change on let alone anything else, but hey it's all about what YOU want.
The Eco looks like something out of a Honda. But that 5.0 looks mean.
Get whichever one you like the most. I would just suggest, like others have on here, to do some reading on other forums and what not to see what others think of ones they already bought. I think either way you go you're going to be happy.
What a completely biased, BS post.
Irony...
To stay on topic, asking guys on a GM site about GM vs. Ford will never get honest results, just the same as asking on a Ford site.
I've been towing with a 6.2 6sp in a denali with an '07 and now an '11. I tow 6Klbs and it's a brick front. I tow in the PA-NY-NJ hills, some can be big climbs, but most are rolling hills. I used to tow with an 8.1L (but 9Klbs then), so I have a good comparison.
The 6.2 6sp is a great combination for towing. Personally, I would never buy a 5.3 or similiar unless I was only towing 1-2 times a year. I tow 10+ times a year.
For mpg, I don't care. I consider it 'pay to play'. But, for you, while towing I can get 10mpg if I take it easy, 65mph, letting it slow a little up hills. but usually I am in a hurry and want 75mph, and she gets 7-8, and even 6 if it's all hills and I keep it at 75 up the hills, which the 6.2 enjoys doing.
Best of luck.
I am old, and am of the opinion the more displacement is always better, and why I have a 6.2, because gm was the first to build one for me. And I had 8.1's before that untill they were discontinued. If a 7L or bigger comes out, I will buy that. But it has to be in a half-ton, for my old bones.
And here's some mpg opinion. Your spending $40K on a truck, I don't think a couple mpg means much to make it do what you want it to do, even at $5/gal.
Bang for the buck, the 6.2l NHT GM truck is hard to beat for regular light to medium towing and all around use. I can totally agree that the Ford's CC interior lays waste to the GM's cramped and horrible lint magnet seat covers but all around that's about the only real thing that I see where Ford has the upper hand.
The EB while a good idea and an engine that makes all kinds of usable truck torque will always be "in the turbos" while towing and it will eat your mileage alive. While I only have light weight towing experiance with my '11 6.2 Non-NHT Silverado (3000ish lbs) I can say that as long as I don't drive like a maniac, it will still pull down decent mileage pulling that load (11.5-12.5 mpg). Mind you, this "load" that I am talking about is also a not so streamlined brick of a enclosed snowmobile trailer as well so that doesn't make
for great mileage, no matter what plus, that's in the small rolling hills of Northern Michigan, in the winter, trans in 5th gear. Therefore, I'd expect to see similar mileage pulling a near 5,000 lb load in the summer.
As for the 5.0l vs the 5.3? Sure on paper the 5.0l has the 5.3 covered and I'm sure it will get comperable fuel mileage as the 5.3. Considering the low count of past and current issues with GM LS based V-8 engines PLUS the better factory powertrain warranty, the desicion there is still tough as well.I see the 6.2l Ford engine as nearly non-existant considering that I can only get one if I want to buy one of their top of the line trucks and that's not going to happen so, ixnay that idea.
Anyway, I am happy as can be with my non-NHT 6.2l Silverado. It runs like a scalded dog, pulls extremely well, gets fair fuel mileage and brings a smile to my face everytime I drive it on the expressway or from stoplight to stoplight. The rest is your money, your decision.
Haven't the new fords been having trouble with tranny's?
I just recently picked up a 6.2 and she's been putting a :) on my face with the power over the 1100 miles I got on her
This is the reason I am no longer in a Ford. Out of the two F150's I've had BOTH had transmission issues. After replacing the tranny in my 2005with only 66K miles on it I had a sour taste in my mouth.
No question, the 6.2L is the much better truck. That EcoBoost will kill your wallet towing that trailor. Their owners complain of terrible, almost unbelievable gas mileage while towing....Should not be a hard decision for you to make.
What a completely biased, BS post. No the EB won't get much, if any, better FE while towing than the 6.2L, but it will get much better while not towing.
Would you expect anything less form a GM forum??? :idiot:
I have 2010 6.2L with the NHT package and all I can say is coming from a couple Ford's this is the far better option. I have no problem towing my 25" boat. or anything else I throw at it. The gas mileage between this 6.2L and the 5.4L Ford I had are about the same. I am getting 13-14 in town and 16.5 on the HWY.
To those that posted about the spark plug issues in the F150's, Ford did finally fix this issue back in 2008. You gotta give them credit where credit is do... this only took two redesigns and 12 years to figure out :rolleyes:
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
