I seem to have solved my oil burning problem
I got my truck from the dealer, and I don't know what they put in it for oil but but my trucked burned through 2 qts. in 3000 miles, and it was ticking. So I naturally thought I had a problem motor. So I figured I would gives AMSoil a shot, and I am ecstatic to report my truck has not burned a drop of oil and no longer ticks. I promise I am not some guy pushing the product, just a very satisfied customer trying to pass along a suggestion to my fellow 5.3 owners with an oil problem.
  • Replies 30
I run Amsoil in both my cars. I run it in my Malibu and it made it run alot smoother and a little better MPG. Also the Tahoe this winter didn't make any noise on cold start ups. Now I can run it to around 4000 miles between oil changes and have no issues at all.
what makes asms oil good . What is in it or how is it made . Is it marketing/precieved value that makes it good ?
Because they pride themselves on using the best base stocks and additives money can buy and they been doing that for 40 yrs. I been using AMSOIL for better than 25 yrs and would not use anything else. It made right in Superior, Wis.
Thats good to hear! Nothing is better than Amsoil! Look in my signature. Lol
I get the signature series that can go for one year or 25k miles if done properly, but I change it every 8k with a filter swap every 4k.
If you want to be helpful, tell us what you did. Did you flush the engine with a cleaner? Just change the oil/filter? If so, what weight did you use? How long many miles have you gone since you changed it out?
DEWFPO
I have no personal experience with Amsoil, but its NOACK volatility number is much lower than most other top tier oils. In other words it's less likely to burn off in high temp service. To meet the new SN requirments 5W-30 has to have a NOACK vol. of below 15%. I believe, Amsoil has always been in the single digits. It is simply better stuff than most.
On my next change I'm going to go to Pennzoil Ultra who according their website has now been dexos approved (warranty) and who is the only widely available and reasonably affordable (Wally World) syn whose NOACK numbers appear to be in Amsoil's neighborhood. (around 6.4% in 5W-30)
If the oil resists burn off it should help with the issues some guys are seeing.
http://www.pennzoil....c-oil/#Benefits
http://www.epc.shell...01112051449.pdf
alot of my fam uses amsoil...i myself like mobil products :dunno: but amsoil is damn good shit...i dought amsoil solved your oil burning problems though, if you burnt 2 quarts in 3k miles, you got bigger problems then a brand of oil
+1, no oil is going to fix 2 quarts used in 3000 miles
Does Amsoil have really good cleaning agents in it that would clean the oil rings enough for them to seat properly again?
The ALS 5W-30 NOACK Volatility, % weight loss (g/100g) (ASTM D-5800) 7.0
t
I know it sounds crazy, I dont really understand it myself. It could have been crappy oil the dealer put in. Maybe it has nothing to do with AMSoil, maybe its just because I didnt use garbage oil in general. Yes the brand of oil does make a difference. My old truck did not burn a drop of oil and I put Castrol high mileage in it one oil change and it burned that stuff up like crazy, it actually made the "low oil light" I didnt know I had come on... I switched to something else and it stopped. All I know is when I checked my oil right before I changed it, it was down 2 quarts. And after 4000 miles on this stuff its not.
DEWFPO
I did not flush it out, just changed the oil with 5w30 and a regular old oil filter. And it has 4000 miles since I changed it.
i'm still calling bullshit on this, i know people that run the cheapest oil and filters they can find with no where near your amount of oil consumption, and they have over 100k on the ticker...
True
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
