I just run 2 10's. Sounds clean.
Sent from my DROID X2 using Xparent Red Tapatalk 2
I got two 10's also. They sound great.
Getting ready to switch my amps out. Boozaka to my Memphis one, I should put my Memphis 12" Mojo in, but I'll have no room if I do that.
Cleaned the truck and hooked the subs up in the bed
Subs in the bed?
I'm taking people in the dunes and we want subs so were rocking them In the bed so I can have passengers
A buddy of mine has a gull wing toolbox, was thinking it'd be cool to mount speakers to the underside of the wings, so when we're at the swimmin hole we could just pop open the toolbox, turn on a second amp, and be set. I think it's worth a shot. With his truck of course, I wouldn't get an over the rail box :lol:
Just finished unloading one load of portable fence panels 5 foot tall by 16 foot long had a bundle of 25 on the trailer went about 250 miles round trip to get them. Son's Tahoe took a crap on him so I unloaded his panels and then went to rescue him!! Tahoe is still on trailer will try and get a picture before it gets unloaded.:jester:
Hmmm...nothing too exciting today. Drove the truck to work, errands and back home again. She may get taken to the drive-in tomorrow night though.
Subs...hmmm I haven't used mine in quite a while. Maybe I should hook mine up that's in the basement.....
By the way what are the Dunes you speak of?
Tomorrow I'm hooking up to the horse trailer and taking 3 steers to get ear tagged for this years county fair
This is the dunes hahaha its a magical land where trucks quads dirtbikes and buggys (and some cars) roam free
this hole was up to his door handle deep
My buddy tim tried to help the buggy but got stuck so dustin with his 9" lifted ford f350 gets in there and im standing aside waiting to pull them all out hahaha dustin ended up getting them both out
test hill
beach
me in "big sexy" haha i was dancing
such a great day
Oil change , Inspection.
Then later on in the day noticed a 4" puddle of oil on the ground that was leaking from the skid plate.. So even after I payed someone to change the oil so i didnt have to get full of it.. I still had to get full of it cleaning off the skid plate and pressure washing the driveway :banghead:
When will I learn just to do it myself and not have to check on other peoples work / cleanup after it... :rant:
Truck is b!tching at me for an oil change. I hauled 2 steers and a heifer to get ear tagged for the fair and then took the heifer out of town to be inseminated because she has to be pregnant for the fair to be entered. Ill pick her up in a couple weeks. Ill be changing oil this week. Ordered the test kit from Blackstone late Tuesday night and got it Friday. They are fast.
Ive had 2 tests done by them so far.. my last one i requested another kit and they sent 5, lol.. I'm set for a while now.
My mechanic laughed at me and told me im wasting $ with the analysis but its piece of mind to me.
I know after every analysis i do not have coolant in oil..
I got 2 12's in mine and i everyone says its loud as hell but it sounds kinda quiet to me haha guess my hearing really is that bad...As far as working on my truck im going to try and crank the torsion bars some
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
