I think my blower motor resistor went today. I can't use the "5" fan setting
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
If you lost five it is likely the high speed blower relay, not the resistor. Check the plug though as they do melt on the resistor harness.
Is that in the box under the dash?
power steering pump has a blown gasket or seal whatever so thats leaking
both wheel bearings need to be replaced
my amp needs to be hooked up again because i hit bumps and the bass stops
fml
the end
Washed, clay bar, amd waxed today... just to have it rain on ot a few hours later... I hate rainSent from my SCH-I535 using Tapatalk 2
Changed dash... Cracked near top left corner of airbag. Gm helped fix it, so it's all good.
Apparently everyone w a 2008 and up eventually gets the same crack.
michigans finally warm thats all i care about
This!
Wasn't with my truck but I went with a friend in his '69 Chevelle to a cruise night at the Halo Burger in Grand Blanc. Quite a few nice cars on display.
Edited by MikeNH
I love Chevelles. Very cold here today. Worked on outfitting an 07 Cummins with balebed and hydraulic pump. I'm glad my pickup is so easy to work on under the hood, it's a bit of a chore just to get off the belt on these Dodges.
That's one thing I've always liked about GM's Trucks.
mine went while the heat was on 5 the resistor melted and blew smoke into the cab it melted so bad that the fans stayed on i had to pull the fuse.. the resistor is under the glovebox on passenger side right in middle closer to door, go in unplug it if you need to, if you are under i believe 150,000 miles they will replace it for free since it is under recall
I'm at 117,400 as of yesterday. Does the box have to come off?
Nope, just drop your cover (no need to take it completely off, screw by console can stay) and it's pretty much right there. It's a pretty easy fix.
It pissed me off. 95 out had the A/C on cold and the fan on 5. Stopped at the gas station. Started the truck and no air blowing. Works when set to 4
