we have 93.
drove the truck and changed the oil in the camaro
Edited by RyanbabZ71
filled her up again with 70 bucks worth of gas, did some figuring and i pulled 16.8 mpg which is pretty good
You must drive like an old man. :lol:
Just discovered the station next to my apartment sells ethanol free gas. It'll be interesting to see if the truck does better on that than E10 premium. My mileage still is less than stellar cause I've become horrible with being a lead foot.
Look at the speedo. Almost the entire trip I was going 75. Truck gets 11-12 on the same trip
Ryan
Hey Ryan, you are not the only one that can do that!!! :jester:
Jim that is illegible
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Yea I can't see it either
Ryan
Ryan
On the quiet stretches of highway here I run 85-90.
Sorry for the bad night time picture but it was 20.7 MPG!!! Not bad for a late model oil burner if you ask me. :jester:
Not today, police everywhere
Ryan
Not today, police everywhere Ryan
Yeah I noticed that last night. MSP was all over I94 and I'm sure they're saturating the other highways too. Whatever, I don't have plans for the weekend so I'll let them bust drunks and idiots foolish enough to be wreckless on a holiday weekend. But that isn't the norm- going up to St. Ignace last Wednesday I saw one police car in 270 miles. And none driving back the following Sunday. In rural areas I think they also provide local police services so they have better things to do than sit on the highway.
Greased the slip yoke this morning, didnt have much lubricant in there. NJ has 93 Octane as well.
Edited by BruceDeuce
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
