Changed the oil a few days ago. Noticed the steering rack was seeping. Made an appointment today for that and the transmission tube fix since the warranty ends at the end of the month. Then cleaned her inside and out.
Heading across state today been awake since 2pm yesterday, instead of boring gas consuming highway I'm taking scenic route hitting all the farm towns. It's not bad.
^Sounds like a nice day. Went down south and had a nice lunch before doing some vegetable shopping and making it a lazy afternoon.
Installed the Scangauge 2 in my truck
I thought about putting mine there, but I decided it was easier to see up on the dash. I've had a few people ask if it's a "tuner". :lol:
It's not bad with it there. I used to have my tablet there. But this time the lower compartment is usable and so are both cupholders.
Well me and Ethan replaced an inner tie rod because it was blown tomorrow our friend will align it should be good to go after that we will replace the driver side soon since its on its way out eventually.. Going to truck warz tomorrow as well. Just relaxing with beer right now.
Not much. Been a great week in Vermont seeing friends I only see once a year and a few I haven't seen in ages. Truck is gassed up for the short hop back to NH tomorrow. Then its office duty most of the week until I head back to Michigan.
nothing
Hung out around some cool cars and worked the camarocross event
Thats me in the yellow vest (photo taken by a guy from GM)
Only a few casualties. The worst being the ZL1 that hit a barrier
I got the best look ever when I bought these
did that stop your PS leak? replace seal?
Not really but ya not leaking red so I'm thinking it is still leaking old fluid, I'm going to get some Lucas stop leak
Running the start line on Class 1-3 camarocross this afternoon.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
