Fueled up
Just passed 38k miles
4 yrs 2 months since purchasing (Nov 2009)
Ryan
Wow you must work right around the corner from your house cause I do a minimum of 20-25k a year. I think my dad put 35k on his truck in the first year he owned it (bought December 2009). Has about 145k on it now. More than most older trucks lol
Sent while drinkin' a cold one...
Drove 2 hrs to class, and gave blood, now sitting in class wishing I was on one of my perscriptions
Fueled up
Ryan
Damn I got almost 58,000 and I'm not even at three years. Only did 12-13000 miles last year I think. Probably my lowest since high school.
13 miles 1 way to work. When we travel 75% of the time we take the van.
Plus in the summer I rack the miles (sarcasm) on the camaro (currently at just under 2800, will be 2 in April)
Edited by RyanbabZ71
I've had my truck 2 years and 16 days tonight it showed 47,444 miles!! I guess I drive alot!! It has about 20,000 of those are pulling a trailer of some type. Gotta love the DMax. :jester:
I'm just over Ryan's numbers. Got the truck two years ago March 25 and have 19,315 miles on the truck. That's with a 3000 mile road trip to Georgia. BTW, OnStar Remote link app is awesome, home sick and just pulled the odometer reading from my couch. My tire pressures are...
Not to happy about my finances beetle. Replaced the battery early and it took 2 of us and YouTube videos to finally figure that thing out... Wow is all I got to say about it..
Got you beat. I set off the horn/locator for my truck while in Saudi Arabia last March. :lol:
That could freak some people out. I like it.
The best was when I had my 2000 in college. Friends and I were hanging out at school in a grassy area. My truck was not to far and could see (end spot). Guy walks up and is checking it out, I was like watch this hot the alarm guy jumped and took off running. Bet he had to change his drawers haha
Ryan
I got some Delphi Weather-Pack connectors in the mail today
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
