22s an 37s is not a bright idea if your using it for a hunting truck haha. Stick with your 17s and get a good set of 37s an call it a day
22's are too much I was going to do 20's. still has a good bit of sidewall and I like the look just not sure if I want to drop that kind of dough on another set of wheels and tires. this would be the 3rd set in 4 years haha
I'll probably end up getting 37's for the current 17's. My choice of tire would be Toyo OPEN country M/T either way. great reviews everywhere I look
Sent while cruising down a back road...
Get 20's if your gonna get rims.. And the toyo MTs are the best.. Best looking tire and you get great miles out of them
My cooper discoverer stt's have over 20000 on them and still look and perform perfect with regular rotations every 5k
sent from my truck in a field
I got 30k on my Dick Cepek FC2's and they still have half tread, but I'm thinking they are cupped causing my braking issues I've been having lately.
Was looking at these, but the bolt pattern is a dual pattern (6x5.5 + 6x135) which I guess is good for resale purposes
The ones I really wanted were discontinued. And trust me compared to most wheels these are the only decent looking ones. All the other ones have ugly designs or too "busy" for me if you know what I mean. I like a simple design cause those always look the best IMO
Machined look gets dull looking too fast if it's not clear coated.
My first aftermarket set of wheels were Mickey Thompson Classic 2 and they were polished aluminum. Looked awesome as hell nice and polished up but they weren't clear coated so the shine disappeared in a couple weeks
Don't be a pansy rdnckhntr94. 26s or bust
Sent from my LG-D800 using Tapatalk
Not rockstars
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
