Hauled this. Wow it was heavy, unloaded it myself with a rather smart(only because it worked) trick with a ladder. Put a 2-3 inch scratch in the back bumper in the process, sadly, but didn't go all the way through the paint so you can only tell up close.
Edited by SnakeEyes
I don't think my truck likes me:
Put a bunch of scrap in the bed and she squattn good. Also have the trailer hooked up cause bossman said I can take a bunch of scrap from work with me. Separated the stainless steel and copper and regular scrap. Should be a nice bonus tomorrow [emoji106]
Sent while in 'Murica...
Edited by rdnckhntr94
CJ, that aint no load, I need to find the picture of my old 99 C2500 with a load of scrap that had the nut on the trailer ball where you could only put a 24 oz cup under it. It rode on the snubbers for 120 miles, never got over about 45 mph on that trip. :jester:
I heard that! Hollar at me if you need some some help taking out some hogs or deer. Have gun(s), will travel lol
I hear ya, I got to fill my freezer almost all my meat is gone.
Have ya heard about my vehicle luck lately? Haha its a load for sure for this thing
Send some of that deer meat my way, Closest thing I can get to wild game meat is from the local market that hunts wild boar in Lithuania lol.
Well I'm not doing it but I have a guy here at my work refinishing my rims on my 05 Silverado. Been wanting to fix these rims for years as the clear has several areas that have been destroyed by wheel weights.
Edited by BIGDOGx
Last deer i killed was this past summer, it's been a while for me!
Been there before haha a truck bed full of really heavy bricks will do it for a half ton
Bout 6 years ago me and my dad busted up a concrete patio. It took two trips in my truck (back when he owned it) riding on the snubbers to the landfill. Pretty sure he had to get the axles replaced cause I'm pretty sure that's how he bent them haha
Cool reflection shot
Ryan
You didn't drive through that puddle did you? If so I'm guessing you had to go home and wash and wax the truck lol
Wow! Poor guy just takes all kinds of abuse on here lol!
He knows we are messing with him. I get busted on for always breaking my truck, it's a tradeoff hahahaha
Didn't drive straight thought it didn't feel like it. The back tire did catch some of it (photo doesn't show wheel well all that good). FYI I do t wash the truck nearly as often as I would like its a DD and dirty more than it is clean the car on the other hand is a different story
Ryan
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
