Wow.
I second that.
My Accord just cost me 1,150 with excise tax(OK version on an auto sales tax, applies you buy the vehicle with first registration, so compare to many states sales tax on vehicles its not too bad)), plus registration, tag, title transfer. Next year it will be about $95. drops to $65 at year 4 or 5.
26k MI commercial plate is $560 a year. Because commercially truck has to cover GVWR of both truck and trailer.
Here in Ontario, you have to pay a 13% tax on the appraised value of the car. So as an example, I paid $900 for my 1991 C2500, but my truck was appraised at $3500 and that's what I would have to pay the taxes on. Thankfully I know a guy and he appraised it at what I actually paid for it. Then after that it's $108 (for any vehicle, bikes are $94) every year for new stickers for the plates (up from $87), and if the vehicle is a 1988 to seven years old(currently 2009) it has to be emissions tested every two years, if you live in a populated area. If you live a certain distance (I wanna say 250km) from a 400 series highway you don't need to emissions test your vehicle or if you're plates are farm plates. It really shows that the emissions testing is nothing more then a cash grab in Ontario...
Edited by Daly
That's all emission testing is, no matter where you go, or what country you live in. A giant vacuum cleaner for your wallet. :sick:
Wow! Thought I had it bad with $83 Registration on my truck and $36 on the car!
That's why you can afford the $12 12v cover lol
Ryan
Ryan
Lol! I guess I'll have to thank the state of PA.
I broke off the inner driver side door handle. 730450 miles. Downerrr
I ordered a Norris Motorsports catch can for mine.
Good choice
Ryan
Good choice
Ryan
I had one before on the 2011. Really liked the quality of it and the price point.
Chevor, you better trade that pos off if the door handles don't last any longer than that!!!! j/k With every one complaining so much about their trucks its the little things that when they break just seem to wreck your day. My wife has a Ford Exploder and a rear outside door handle broke on it its a 2006 model and the door has not been opened but maybe couple hundred times not to expensive to repair just a pain. :jester:
Can't sell you a new truck if your old one lasts forever .... :chevy:
Put on my 2016 license plate sticker. A sticker for $250??? At least give me a key chain or something
Ryan
For one year?
Maybe that should be their new slogan. [emoji1]
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 504 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
