Wow, glad she's ok.
For what it's worth, my wife loves her AWD Traverse. She hates driving my truck (says it's too big), but this thing is almost just as big!
Jesus Christmas ... glad she's alright!! Wow that could've gone real ugly really fast.
It's either going to be another Equinox or Acadia. She really likes the Acadia Denali interior but the price tag on the Equinox is a little more checkbook friendly..... I guess I will know for sure within two weeks. Plan on going to the dealership tomorrow if she feels up to it.
Plan on taking a peek at the Buick Enclave while we're there too.
Sent from my iPhone6
via TapaTalk
Edited by BlackZ71Silverado
Went on a rescue mission. My other half crashed her Equinox on her way to work. Roads all dry until going around a blind curve that was blown over covered in snow.
If she would have hit one foot to the right it would have been head on with a tree. Luckily all is well, just scrapes and bruises luckily.
Looks like it's going to be time for a new GM crossover or SUV, selectable 4x4 or AWD, doesn't matter. It's probably going to be another Equinox since she loved the 08.
I am now a huge fan of airbags, it saved her this morning.
via TapaTalk
Glad she is ok.
I really looked into snow tires before buying the CX5.
Saw many many statements from people in northeast saying winter tires (on a fwd)are WAY better than just all wheel drive in the snow. Remember hearing an auto podcast where a guy said he would always choose Snow Tires over AWD if he was forced to pick just one. That was my plan with the CX5 but yet to use them, has been a very warm winter.
No added maintenance, repairs, or initial cost, or decreased MPG for a commuter that is never driven off road.
Edited by SnakeEyes
The Ex had General studded snow tires on her Cruze. Drove like a totally different car in the snow.
Glad the Mrs. is ok. As for airbags, yep, I was in crashes with deployments and things could've probably been worse had they not been there.
via TapaTalk
Were you not a fan of them before?
Sent from my SM-G900P using Tapatalk
I run snows on all my vehicles in winter. Have to where I live. Makes it easier to go straight to my house, instead of 5 miles out of the way to go around a big hill. Plus, if I'm ever unfortunate enough to have to venture into Worcester, I might have a better chance at making it out alive ... :uhoh:
The entire city gridlocks every time it snows if the weathermen don't announce it. What a hellhole ...
Edited by Jsdirt
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
