Im waiting by the window for ups like a child trying to stay up for santa. Tire shop closes at 5. I have to have 5 tires done
Edited by Chris
Im waiting by the window for ups like a child trying to stay up for santa. Tire shop closes at 5. I have to have 5 tores done
That's me with every truck part I order too.
As much as these cost i want them on immediately. I wish i had the equipment. I used to be pretty quick at mounting and balancing
I'd love to have the equipment to mount and balance. I'd also love to have a lift. Someday maybe.
There's a guy on GMFS that is selling brackets that he makes to convert the 800's to the strut and coil spring suspension. It crossed my mind to do the conversion, but there's a lot of factors that I'm worried about.
There's absolutely no way I'd trust just a bracket. The frame needs strengthened big time.
That was my exact thinking too. All the kit contains is a lower bracket and an optional upper bracket to help strengthen the upper loop. I was worried that this could end up causing a lot of issues later on down the road which is why I'm skeptical. The only other kit I saw which is made by another company is basically the same setup, but it contains something like a strut tower brace that the other kit does not.
Old tires will go on the Expedition
How's she ride? Edited by Daryl Z71
I'd want a hoop over the motor and boxing all the way back to where the torsion bar crossmember is. Could be a fun project.[emoji38]
Sent from my SM-G920V using Tapatalk
Maybe some day....
How's she ride?
Rides great. I need to drop the rear a bit.
Oh yea, definitely needs a drop.
I am going to do a 2" drop shackle.
Nice, your trucks going to be a sports truck. I was going to add a helper to mine in the rear, but I think I'm just going to add a 2" block.
Should have already had a 2" block.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
