Yesterday marked one year since my truck got hit by a piece of metal that someone drove over. It left a dent and scratch right below the left rear window. I still haven't fixed it and feel guilty every time i see it...
If it wasn't my fault and completely unavoidable could i have gotten it covered by the insurance without having to pay the deductible?
Other than that I haven't driven her since Saturday and hopefully won't until Wednesday or Thursday!
Edited by white1500
You could spring for a 6.0 gauge set and get trans temp. Also both of those are wrong for your truck. The gear part is different for 06-07
Here is my gauge face. Actual GM Part
I see, good to know. What all is involved in getting the trans guages hooked up an working. That would be a nice feature to have.
You can buy a monitor for much less that can do way more than just transmission temp.
Sent from my SM-G920V using Tapatalk
I was looking at getting an Edge monitor eventually and mounting it in the cubby hole in the middle of the room. It even has a back up camera system that's plug and play for it.
The CTS does. I considered it, but I'd like a bigger screen so I'll replace the radio eventually with a capable unit.
Plug and play
Then why didn't GM just put it in every truck? Ugh.
Who knows, but a sponsor on here can set you up.
Which monitor do you have? Is it plug and play into the obd port?
I have an Insight CS, got it from another member (thanks CA). It plugs straight into the OBD. Right now it displaying 8 things. 086FB04A-32A1-4946-B563-DDD970E1F762_zps
That looks like the same device that's on my brother's Duramax out back here.
Just went and fired it up this morning. Block was -17°F 48 hours ago, and now it's 52°! Craziness. Looked like it was pulled from the bottom of a lake. Totally soaking, dripping wet. Fantastic for the electronics ...
Ran it for a bit, and got it up to 135°, just to burn all that condensate off.
I would like to also check out app based monitors so I can just use directly from my phone, a friend used to have one on Lexus IS300 and it was pretty cool.
I don't really tow but it would be nice to view transmission temps and stuff like that.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
