Drove home
Tomorrow will hit 60K
Been hinting to the wife I need a new one. Gotta start to wear her downf5b4fc4b33b0ee797020a6a24f0a3b52.jpg
Ryan
If i was looking for a truck I'd buy yours outright.
Spent some hours cleaning the beast yesterday since my Aunt and Uncle decided to make a surprise visit and I wasn't about to have them drive me around in whatever sardine can of a rental they got. First sunburn of the new year for me too. The beast isn't completely clean but it's a lot better than before. I really need to get better at doing glass, never seem to get them streak free on the first try, always have to go back and do them again a day later. Might be all the crud that builds up since I wait so long to do it, wouldn't matter if I was a day walker, driving at night everything is visible...
Back when I was at the dealership one of the guys in the wash bay told me he used newspaper to clean glass (with spray cleaner obviously) as it didn't streak. I was skeptical but it works and it's what I've used for like 12 years now.
Been using newspaper longer than I can remember.
Yep, same here. Also of note is it seems the formulation of Windex isn't what it used to be. Stuff seems to CAUSE streaks rather than remove them, even with newspaper. Glass Plus works alot better.
I've had great luck with invisible glass. I spray it on the glass, wipe with microfiber, wait a few minutes and wipe it with a completely dry microfiber.
Edited by kstruckcountry
I started using the invisible glass myself about a year ago. Works pretty good. Definitely going to have to try the newspaper though.
I use invisible glass with coffee filters. Streak free and lint free. Also very cheap.
Edited by NEFisher11
I think I did 9k this year - and that's only because I made 2 Florida runs. The less I use it, the less I have to work on it. :D
Mine sees 13k-25k per year. 2015 was a light year at 13k. 2012 and 2013 got 23k and 25k respectively
I've also had really good luck with the Griots Garage spray window cleaner. I basically buy whichever is cheaper at the time.
Sent from my SM-G900P using Tapatalk
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
