Well while driving around yesterday & noticed the truck making some noises I discovered my passenger side hub bearing was toast...well flompy doodle!!!
Another $260 spent, but at least I know both front hubs are new & under warranty. No issues in replacement, used Moog just like the driver's side. Did have to reuse the axle nut until my order comes in. My order was suppose to be here today but a mix up at the warehouse delayed it another day. Hopefully tomorrow...
Didn't take pictures again! I had replaced the head lights about 90 days ago when one burned out. I watched a You tube video on how to do it and followed it took a couple of hours to pull the front end Yes I did say front end off the truck to change them! You pull the grill and bumper cover off along with the raditor cover and in the video I watched they pulled the front inter fenderwells down also. I did this on the drivers side and then realized that I did not need to do that at all. Took less than fifteen minutes to put it back together and now I think I can change them out from start to finish in less than an hour. Wish it was like my old 99 took about 15 seconds to change them out on it. :jester:
Won't be doing much out there today.
Got woke up at 4am by my CO alarm. Friggin stoker was jammed full of wet fines (ground up powdery coal). Had to drag my shop vac up the basement stairs, and outside into -17°F air. That was fun, lemme tell ya! Vacuumed out 120 lbs. of coal from the hopper so I could clean the feed paddle. Pain in the ass ...
House is 65° right now - can't get any warmer. Stoker is burning flat-out.
Edited by Jsdirt
Good thing you have a CO alarm! Edited by SnakeEyes
There's no real danger in this 166 year old drafty barn. So many air leaks, I'd have to huff the chimney directly to get poisoned. :lol:
Looking at an 04 LB7 Dmax crew cab as a new play truck. Shouldn't have gotten rid of my 02, time to upgrade the play truck I guess lol
Edited by rdnckhntr94
What's wrong with 65? We keep our house 65-68 in the winter
Ryan
Ryan
Mine stays at 67 on the few winter days. In summer i keep it at 78
Ryan
We normally keep it at 72°, since I installed that coal stoker boiler in October of '13. Before that, we spent many winters getting out of bed into a 55° house. Not very pleasant, to say the least. :shakehead: But 65° ain't bad at all, especially considering there was a 82° difference between indoor and outdoor temps - got down to -17°F this morning.
We started burning coal in a hand fired stove in '05. Was WAY undersized for the house, so below 30° outside, we froze in here. Lots of temps in the 50's. Bought a bigger unit in '08 just before the big panic hit, and lines of people filled every stove shop in MA. Installed a couple large stainless hot water coils in it and tied it into our oil boiler. That kept us comfortable (except below zero), but it was a hungry beast. Good thing about coal is you only have to mess with it every 24 hours (shake ashes out, and load coal in), but I had alot on my plate at the time ... and then a few tons of coal with rocks in it jamming the grates open pushed me over the edge. Sold that, and installed the stoker boiler. Just like a pellet stove, except it uses fuel that doesn't go bad when wet, and has 30% more BTU's per pound. It's hands off most of the time. I spend 5 minutes putting coal in every 24 hours, and I take the ashes out either every 24 hours, or week and a half, depending on weather extremes. Still cheaper than oil at the current prices here.
Chimney pipe install is far from ideal, but gotta run with what you brung. Not quite to code, lol.
Anyone know if this will work in my truck?
Mine
Edited by Chris
That looks like the '07 and up new body style to me ... but I'm not 100% sure on that ...
Wow fast typers here! Chris beat me to it.
Edited by Jsdirt
That is the 03-06 Platinum
Ahh 10-4.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
