Glad everyone is alright. I personally am a believer in air bags. Years ago I was in an accident where the air bag did NOT deploy and my head ended up bending the steering wheel. Fast forward to Jan 2015 when my truck was hit I was still going 55mph so if the air bag hadn't deployed I probably would have been in a much worse state.
My Silverado was the first vehicle I've ever owned with airbags. Thankfully I haven't had to test them out yet ...
What they do? Make the front like a Pogo stick?
The install or just keys period?
They destroy the front end by stressing out the cv shafts due to horrible angle and the control arms are slammed against the bump stops. I had to fix 2 trucks last summer/fall because of it.
Sent from my SM-G925V using Tapatalk
I figured they'd be hard on some of the suspension. Any idea if the ones you had to fix were higher than 2"? Supposedly anything over that is really asking for trouble. If they start causing issues I'll just pull them back out and go back to stock.
When I leveled my previous truck with keys I only brought the front end up about 2" and that's it. So my angles were too much steeper then stock. Didn't ride any stiffer either. If I do anything to this truck it will be to just crank the currrent keys about "maybe" an inch at most.
I suspect someone did this mod to my old '94 K1500 I had prior to buying the '07. Thing rode like it had no suspension. That was the only thing I hated about that truck.
You can crank the stock keys and get almost 2", if you exceed that you're asking for premature suspension wear. Never made my 02 ride bad though, but they also weren't cranked to the limit
I was going to just crank them, but with 240k miles on them I didn't think I would get much out of that if anything. I've read that some people with a lot of miles didn't get much from cranking them...
There's a guy on GMFS that is selling brackets that he makes to convert the 800's to the strut and coil spring suspension. It crossed my mind to do the conversion, but there's a lot of factors that I'm worried about.
On my 02 the torsion bars were actually twisted, had to get new ones. Check yours when you break em free
That's wonderful. Maybe I'll just do the conversion if they're like that lol! Where did you get new ones and what did they cost you?
They also sell coilover conversions for the 2wd
Just a local junkyard. I think I paid 75 a piece for them, but this is northern VA so they rape you on everything. Should be able to pay around 50 a piece elsewhere. Just look for the donor truck to have low miles and the same codes on them (there should be a little tag towards the rear of the bars)
Okay. I'll have to check mine over. Hopefully they'll be okay, but who knows with my luck.
Im still waiting on tires. They have another hour to get here. I paid UPS $8 per shipment to have it come between 2:15 and 4:15
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
