The ones I pulled out were AC Delco.
I was friggin' amazed they actually used anti-seize compound on the threads. Miracles never cease!
I have bought ACD's from the dealer that were marked NGK.
Well, that explains the striking similarities. I didn't know that. Interesting. Never know who makes what these days!
That's how a lot of my ideas come about. 8hr work days full of boredom.
I wanted something cool before i went since Zane and Josh were going to be in my truck
Show off [emoji1]
Show off [emoji1]
Had to have something to show. But the original install didnt work right. Dodnt put out enough power to charge Samsung phones that needed 2A+. So my S5 and their S4's wouldnt charge with it. Had to change that setup in may prior to our trip to Willow Springs.
Well, I throw my phone on the console and it charges. :driving:
Sent from my SM-G920V using Tapatalk
Did you install a wireless charging pad on the center console lid?
Wish I was down there with ya right now. Getting hammered with snow .... :nonod:
But that doesnt give you android auto
Yep, $25 3 coil Qi charger. Gutted it, took the lid apart, punched a wireless charger sized hole, and a hole for the USB wire to go through. Then put the rubber liner back on the lid and done. I haven't hardwired it yet, but I'll get around to that. It works with my S6 with lifeproof, also works good with an S6 edge in a Speck case. Edited by kstruckcountry
Finally got around to installing PowerStop brakes front and rear Z36 pads and rotors with PowerStop shoes on the rear. Huge improvement over OEM, it's like driving a different vehicle while stopping. Best upgrade to my 2010 so far.
Feels near identical to the EBC's and Hawk rotors on my 2008. After towing with the 2010, i'll know for sure but it feels about the same.
Edited by BlackZ71Silverado
Looks like I'll have to try that out when the time comes. I have EBC Yellows on the front, with the OEM shoes out back. Been very happy with it.
The brake job before this one, I used Wagner ThermoQuiets front and rear. ABSOLUTELY TERRIBLE! From the very first application of the brakes, I was regretting my purchase. I have the same brakes in our '86 Grand Marquis, and that thing will put you through the windshield with little pedal effort. Total opposite result on the truck. Could have been non-metallic pads I got - that would explain alot. Towing was frightening. Had to stand on the brakes, even with the trailer doing most of the stopping. I put up with that for a year or more before I finally threw the pads and shoes in the trash, with many years of life still left in them. I just couldn't take it anymore. The EBC solid rotors, pads, and rear shoes brought back the feel it had off the showroom floor ... minus the pulsation. The break-in procedure was similar, but I have always used that same procedure with all brakes.
I'm curious to hear how good this setup will be.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
