Still no hydroboost I see...
Nope. Its on a to do list, barely have the time for this project. My truck needs to be driveable by 3 pm tomorrow
When I was in my 20's we used to go to Templeton every weekend. That place was awesome. There were a couple large sand pits, and miles and miles of trails - pretty much every style of riding right in one location. Loved that place. We pretty much lived there every weekend in the early to mid 90's. We'd park, then ride trails, cross Rt.2, and play around in that pit next to the highway. Some crazy steep hills there. Used to love that. I think I have a picture of me riding the hill in the area where we used to park - can't seem to find it though ...
Last time I was there was in '04 too, in winter. I had just bought a brand new Kawasaki V-Force 700, and the wife and I took a cruise around on some snowmobile trails. Wow - learned real quick that people don't like that, LOL. Some waved, others flipped me off, some swore at the top of their lungs at me through their helmets. Didn't figure it out until I got home and told someone who was into snowmobiles where I was riding ... :lol:
That place is totally off limits to motorized recreation now too. This place is getting worse and worse by the year ...
Yeah it's sad. NH still had a good amount of class 6 roads but who knows how long they'll last.
Got the fronts off before calling it
If I didn't live 3k miles away I'd help you. Be done in no time with everything
My back is killing me. Got the fronts together. Now after a break i need to start on the rear. Have the swamp cooler going. Still have to call my stepdad to get these bled. After wheel 3 i will text them. Wish i bought the motive bleeder, but could not justify the $70 on it
Packed up my stuff and heading to Californie.
Upland
Dispatcher said pays 2085 miles, GPS saids 2096 errr.
Edited by Chevor
Done. Just need to bleed now. Tires are marked for rotation.
New rears
I have a motive. Used it one time and that's it. Tried three different attempts at using it when I bought it and all it did was leak everywhere. Couldn't get it to seal to the master cylinder to save my life. Really pissed me off.
I cant get the back right to bleed. A little fluid comes out, no real pressure. Caliper doesnt even move when pedal pushed
Supposed to bleed that one first
Chris, check that bleeder for machining debris, or a missing hole inside - believe it or not, I've seen the latter more than once the past 5 years. Had a bleeder once that wasn't even drilled on a brand new caliper, wtf.
I just did a front brake overhaul on a '96 Plymouth Breeeeeeeze. That's how you have to say it. Breeeeeeeeeeeeeeeeeze .... :lol:
It left half itself in my driveway, after I hammered on it for so long with an air chisel that it bored a hole right through the rotor. Took me 20 straight minutes with the chisel and fire wrench to extract it from the hub. Welcome to the Northeast! :rolleyes:
Finally got my mulch in
Wiped it down last night got rained on earlier Friday at work
Ryan
Also worked on replacing a wheel bearing on an 08 Malibu
Ryan
I attempted, but wasnt getting anything. It is getting flushed now
b29b9b96c13796b20fca7cf9730cdb3b.jpg Finally got my new cab corners painted the paint's slightly off but whatever it's an old truck just glad to see the rusty cab corners are gone. Just got a install a few moldings and bolt the box back on and put the rear bumper back on and its done.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 640 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
