Oh quiet down, you're still a 100k behind me...lol
385?
My seats are looking awful
Ryan
Okay you wrench jockies with all of these high miles, what should I have in my tool box? Have most everything + other than a code reader...?
Serious, do all my own work and a bone stock type of guy. That is about the only thing I don't have.
In all seriousness, I don't have many tools in my toolbox. Odds are if something breaks on the road, I won't have that tool with me anyways. I just keep the basics. Small socket set, screwdrivers, crescent wrench or 2, random pliers, 4-way lug wrench and extra oil.
I agree with you completely and carry about the same plus my tools from my day job in my toolbox.
Bottle jack, tire iron, fuel filter, oil, brake fluid, rubber hose, hose clamps, 3/8 socket set, air filter, circuit tester, Bulbs and more.
Edited by Chevor
Cleaned the calipers and started painting them with BBQ paint
Peeling all the trim crap off my 2015. I left just the bow tie on the gate and added a little 6.2 badge where it used to say LTZ I got from amazon. The door trim itself isn't bad at all to do but the Silverado letters on the doors are awful lol. The glue does not want to cooperate at all from them. I got the passenger done and have the glue to peel in the drivers side now in the morning. I refuse to use those eraser wheels.. I own one and they make a mess of a dark color trucks paint. I am getting the truck fully detailed and polished Monday. .. should look good. Added the black ck162 22's on it too... once debadged next is a lowering kit...
Sent from my SM-G900W8 using Tapatalk
A heat gun works great if you have one.
Got mine out of storage. Man that thing is nice. And that 6.2 is illegally fun. SO glad I got that beast when I did.
Just makes it smear and it's actually a lot worse. .. it's no help at all. The closer to a 70 degree ambient or so the better and it comes off mostly as one piece. This isn't my first time doing this... it's just the end that justifies the means lol. This.. detail... lowering... turbo lol.
Edited by 1994Vmax
Done! Just needs a good cleaning and to get closer to the earth lol.f906c0b9e332d94c8ffd931b10c14291.jpg
Just cause lol.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,012 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
