I drove across town to pick up my degree since im still waiting on parts
  • Like 8
Congratulations! I bet it feels great!
Took 2 weeks off and started my bachelor's in business. 2 more years
Dedication.
Dedication.
No. VA benefits. Im using the school while i can
Well that's definitely a good idea.
Degree dam I'm having hard time doing my GED lol. Anyway I got my truck back from the dealer and it was still making a rattling noise so I took it back turns out to be loose U Bolts ya the U Bolts that hold my rear diff to the springs but this was GM fault I had OK tire in Saskatoon install 3inch blocks on my truck at about 10 000km two years ago and now at 56 000km I finally discovered what that rattle but unfortunately it destroyed the blocks. Thanks OK Tire.
Ordered this off of Ebay since my headliner is sagging by the door. Not exactly cheap, but it's cheaper than a new headliner for now.
Finally got around to figuring out the mileage from a road trip (1138 miles) we just got back from. It was a treat not to be towing our tt this time. Went up through Montana, over to Washington, back down to Idaho. Fueled up five times differing driving condtions, most on two lane with 65-75 limits and alot of mountain passes with 25mph corners. We had a 14.8,14.37,12.3, 14.85 and 14.2 for mileage while keeping my eye on the tach. Looking back, the 12.3 mileage was a day that we were mostly in-town driving. Need to quit racking up the miles on our '05/6.0 though because we are up to 84,619....
Okay you wrench jockies with all of these high miles, what should I have in my tool box? Have most everything + other than a code reader...?
Serious, do all my own work and a bone stock type of guy. That is about the only thing I don't have.
Finally got to the as antifreeze change. In the interest of time before the big cross country trip I left the old thermostat alone. Finally got all the "must do" items done from when I bought the truck. Now for the want to do items...well and a few other new better get done soon items.
Shoot, that's not even broke in yet! Mine has 200,000 more, and still runs just as great!
Oh quiet down, you're still a 100k behind me...lol
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,012 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
