Someone's confused! :lol:
Started painting. John Deere paint
Or it was a prank
"Socialised" it from a Chevy owner.
Edited by Chevor
I'm just amazed that GM doesn't see this as a problem. You'd think they'd have fixed this by the '08 model year ... but they just made them worse. :nonod:
Maybe GM should stick to building gliders, and let the customers choose the driveline. I'd probably buy another GM again if that were the case! :)
I heard BMW is now telling V8 M car owners that "when it says it needs a quart, add two". I'm they burn oil so fast I doubt you would even need to change the oil.
Not surprised. Gotta love the 21st Century way of quality control, & customer satisfaction!
It's so friggin easy to build an engine that doesn't use a DROP of oil! I've been doing it since I was 16 years old!! :nonod: That's just unacceptable on so many levels ...
Edited by Chris
Just reminded me I forgot to look up that tranny cooler you got there. That's a sweet one.
Well, my engine is probably going to grenade in the next year or 2 ... or sooner, so I should be saving for that first ... :throwup: Such a downer ... :nonod:
Edited by Jsdirt
It's a Fluidyne ThermHX
Got off work and my buddy and I did a quick inspection of my truck in the parking lot, then did a road test. We've concluded that the tires are most likely the reason I have shakes/shimmies while driving. Some of the tires have bulges on the sidewalls. Left front is probably the worst. So now I get to see how and if I can get them warrantied by Michelin. Also stopped by my rental property and had them double check the tires real quick and took a better look at the bay doors I'm going to need to replace. Also dropped off my 12T jack stands at storage to get them out of the garage since they are too tall to use easily on my truck. In about an hour or so I'll be driving to the other side of town to go to a baby shower.
Edited by Chevyguy85
Ordered some Wagner brake rotors for the front of the truck yesterday, the Powerstop rotors must have gotten messed up from the junk calipers I had on before.
Hauled $42.50 in singles from auction. Also have about 90 gallons of fuel aboard.
Edited by Chevor
Finally​ got the tires from my 2011 installed on my '15. Liking these wheels a lot more with real tires on this truck.ef60ead9e9978b9348557d709e5edf97.jpg335b2f52b255aac8d13c9f005e0bb26c.jpg572335626988665a305379bd449539cf.jpg
Sent from my E6810 using Tapatalk
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
