Drove up to white mountains with my father in my truck to do some stream fishing for trout. Truck averaged 16.7 so iam happy with that. Been getting better mileage running 89 octane. Came home with 6 trout so there will be some good eating. Kstruckcountry I agree with you and now plan on getting LT tires this time. Was driving on dirt roads for the better part of the day and couldn't help but think some LT tires would add some piece of mind.
Edited by NEFisher11
Yeah he's got a point - I forgot about nails and screws! Thicker is better on any job site.
I finally started clearing out the back section of my barn in preparation for an addition (and eventually a LIFT!). Got a long road ahead of me there. Lots of stuff back there that needs to be stuffed into the already bursting-at-the-seams front section. Moved a pile of lumber 6' tall.
Got a long way to go, but it's a start.
Put 4 new tires on the truck. Got Yokohama Geolander AT g015. Upgraded to LT tires also handling is different but nice. Much firmer ride.
Working on detailing (clay polish seal). Starting with hood and all 4 doors. Doing the baggy test it was way past due.
9f2f7bc4b982960acb67979b2e364bc1.jpgm
Ryan B.
I would so buy this from you if I was in the market at the time, definitely a well taken care of truck.
Well, hauled this today. Biggest load I ever pulled. Had no problem. The 6.2L did very well. ec4d2c4fdd03cc47f3f0e9392c0ff0ae.jpg
The countdown is on lol. My wife came home from work and said you're not selling it for a new one. Probably the last full detail.
The door trim was pretty bad. Some tar and everything sticking to them. They came out great
I guess your selling the van then. Lol!
She didn't mean I can't sell it she meant it as it looks good and I still like it which I do.
She won't sell the van I tried. I hate it
Ah I see now. Once you see that new shiny truck on the lot you'll forget all about the old one. lol!
I'm going to need a crew cab bad, man I'd love to sell mine and buy yours. Ive always loved your truck. I just can't swing a new one right now with the baby on the way and saving for a new house.
Finally gave her a bath. It's not perfect but it's still better than nothing. It's been so long since I've used that soap it grew its own friend lol. I need to figure out why 2 of my fender markers are collecting water. I guess after all this time the seals are wearing out. b6a752c02b395315bacac1aed3788e8b.jpg51a233aaed1f8904af57cb65fa87a0f8.jpg
Sent from my Find7 using Tapatalk
Peekaboo had to drive the car today truck is to clean
Ryan B.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
