Went through a rain storm last night parked. Only evidence dirty windows and some spots on the hood. The sealant/wax is definitely helping to keep clean
Ryan B.
Damn Ryan I need to detail my truck like you do.
Got him washed yesterday, had a little off-road adventure that was Z71 worthy. 4HI and the Ranchos did quite nicely. Wash turned out well, but I got water trails from the door handles. Oh well, will likely wash again in a couple weeks, my ideal wash schedule is every other week or every third week, weather permitting.
A month back, while looking for a rattle, I scuffed up my right rear door panel a tad, and busted the lower front bolt hole on the front panel. Though I glued the bolt hole, I couldn't live with that or the scratches, so I got new door panels. They look great and it even sounds a tad quieter in the cab!
Replaced my box protector for like the 7th time. My Borla exhaust was misaligned just so that the tips contacted the protector and started to melt it. Gave the tips a nice shove during my wash, and that seemed to be the ticket. Alignment is good, and clearance is MUCH better.
Then today I installed 9000xl shocks on the rear setting 5!
Lovin it!
At 29k I'm getting rid of stockers and getting these!
Getting them installed at 4wheelparts!
What did I do with my truck today (well, yesterday)?
I rolled past 38K and went down to buy my daughter a Chevy Cruze Eco. As soon as I got home with it, she was telling me what mods, that I have done to my Silverado, that she wants done to it.
1) All forward-facing white lights on with HI-beams
2) LEDs all the way around (inside/outside) (I haven't finished this one yet with my truck)
3) Phone holder (current/primary project for me)
I may throw in (when I do mine):
1) Lights under the hood
2) LED strip lights underneath (when I throw on my nerf bar lights)
3) Better trunk lighting
4) Footwell lighting(?)
Edited by Ravenkeeper
Ryan what do you ran your LT tires at for psi? Been messing with my new tires trying to find the right pressure
NEfisher, I'd start at 55 psi (Load Range E), and see how they wear. If you're empty, that's more than enough.
Was going to haul an old metal cement mixer to my parent's tomorrow ... but then I realized my sticker expired in July. That was easy to get out of! :lol:
I've donated enough of my money to the state this year - not even taking the chance.
Edited by Jsdirt
Finally gave her a wash yesterday.
I did the same for my old 1996.
there is still something in that u41 black on black..
got a compliment today.
my locale kills trucks. seeing beyond 8 years in good condition is not all that common.
I inspires me to do more. I see lower back edges of door shells are not perfect.. etc etc.
it might be the LED on the black. that is always very vivid.
I love the newer ones as well.. seeing the DRL LED.
treat 'em good, you get good back.
odometer is now at 363040.
Normally 48. I don't drop below 45
Ok that's where I have mine at now. Started at 55 but that was too high the handling of the truck felt odd.
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   4 Members, 1 Anonymous, 4,881 Guests (See full list)
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
