706,029 - rear tires pulled, still just under 6/32nds left. Replaced with 265/75/16 Bridgestone Duravis R500 14/32nds, full tread. Plan to go switch to 235/80/17s Michelin ATs after it snows.
Control. 235s are just as tall as 265s. Just 1.5 inches narrower. In snow and ice even if the tires spin they stay under truck. Wide size tend to wonder / float. Narrow cut right through.
Edited by Chevor
Yep - most people wouldn't believe a Model T would go through terrain in 2wd that would get any modern 4wd stuck. All due to the super skinny tires.
When they first came out, there were few paved roads - they had to be more of an ATV than a car in those days.
Yup, the winters going on my 91 are 235/85r16's they are about the same size as the 275/65r18s I'm running in the summer (within a .5")…
Now I want to see what the other half of warning sticker says.
Edited by Chevor
Only one station pheasible for me to go to with e85 and last I went the pump was out of order, still is as of a month later [emoji58]
My area: E85 is usually only pennies cheaper, maybe 20 cents on a good day, rarely more, so no one buys it here, so they don't bring more, so it will never be worth it cost wise.
Edited by SnakeEyes
Power>cost.
Except for me between the cost difference of 93 I get the benefit of more power and less cost that is called a WIN - WIN
My truck loses power in direct proportion to how much ethanol is in the fuel.
There was a guy on the first gen site that converted his complete system to E85 friendly, and even adjusted everything to work on it to the point he couldn't run regular gas, if so remember correctly. After a while he tore down parts of the system to see how it was going, and three was a green build up starting in the lines, carb, and some other components. He kept running it for the gains, he wasn't seeing issues, but we were wondering how it would turn out long term.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
