Tire rebalance isn't that big of a deal, I've done front end twice on my truck so it ain't hard to do lol
I have a ruptured ball joint boot, so once it goes bad I want to do the whole thing, including bushings and sway links and bearings (I bought the cheap ones so they're probably about done). May check out CVs (not sure if they're rebuildable). Might do axle seals on front too if it needs it... $$$$
But we have quieter cabs
....lol
You haven't rode in my truck - sounds the same as it did the day it left the showroom floor too. More squeaks and rattles than my '94 K1500 had with 266k miles on it. A fine example of modern engineering ...
Spent the past 3 days overhauling my trailer brakes and bearings. Yanked the backing plates off both axles, and installed new complete brake assemblies - genuine Dexter 7k lb.. Ripped all the brake wiring out (wrong gauge from factory - had 21' of 16 gauge ... which may work if you live in Phoenix, but not New England), and ran jacketed 10/2 down both sides of the frame to each pair of drums, eliminating the through-the-axle brake wiring. Thing stops unbelievably now.
Trailer is only 6 years old - the roads up here just beat the thing relentlessly. Found another angle iron support that busted free. Welded that back up while the backing plates were off - made that task nice and easy.
Got ripped off buying bearings locally. Nobody had the damn things in stock, so had to buy them piecemeal all over the damn place. What a pain in the ass! Local store sells me 2 bearings and 2 kits, because they didn't have the 4 bearings I needed. Get home, and find out they sold me JUST the bearing with no race! WTF ... so bought the races at Advance Auto. Local store has ONE ... the other 3 are 30 miles away round trip. Man, I'll tell ya! Should've just bought the damn things online and been done with it. Think I'd have learned this by now ...
I'm hating the deep tread of new tires pulling. Rubber flexes in corners and wind.
Been awhile since new rubber.
Might be the winter oriented compound of the tires too, unless you got all-seasons ...
My Blizzaks have a noticeable change in handling from my wide summer tires - they don't like being pushed at all. They handle it pretty good though, given how soft the compound is.
No, winter tires. NO need with my weight. The torque of the truck pulling would burn them off in no time.
Doesn't help it's a 265/75/16 on a 6.5 wide rim.
Wide rims with narrowest approved tires are the most stable.
Edited by Chevor
Back? When did it ever go out? :D
Silverado%20front%20left%20edit_zpso3hrp
I'm a big fan of black and chrome.
She was finally washed and cleaned after weeks of random rain. And I'm still liking the meguirs plastic and rubber treatment, so far it's a million times better than the old "horse piss"!
I also cleaned out mud from the wheel wells, inside of the bed fore and aft of the tires, and rear bumper. Imagine if they had invented wheel well liners back in 2000...
Someone say chrome?
Now that's nice just tint the windows and straight pipe it and your all set I'm glad to see I'm not the only chrome guy out there chrome all the way screw that cheap highschool black out look that everyone seems to like. Like ya ill take my $80 000 truck and put black rims on it or plastic dip my factory ones ant I cool there not cool black out look just wrecks trucks now chrome on the other hand just makes a nice truck nicer. Dam nice truck I wish I had it for my 5 th wheel.
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
