[emoji631]
Ryan
No thank you for the opportunity to serve
A big THANK YOU to all our Veterans, today and always. We owe you all a debt of gratitude for this Great Nation. :thumbs::cheers:
$52 friggin LARGE - holy crapper ... :throwup:
Hmm....
Should I have the new ones out on today or literally wait until snow?
That penny is the same concept as a normal one, see top of head equals replace.
Edited by SnakeEyes
I'd run those in summer, but not for long. This time of year I'd be watching the weather very closely.
I just can't decide because it's double the wear bar but the tread looks aged for only being 5 1/2 years old.
But, if I do keep this the max of two more years, I might as well start using my new ones now. (Two years because I'm hoping all the things I'm interested in has Android Auto by then)
Edited by SnakeEyes
As long as it doesn't feel hard as a brick pinching the tread with your fingernails, I'd run them to the last minute. Hard tires get scary in inclement weather.
Definitely wouldn't run those in the snow, though.
Yeah, but since I won't keep it long enough to wear out the new ones (70k Treadwear warranty and read a review from a 900 owner that backed it up) Might as well get their benefits now. Edited by SnakeEyes
Guess the previous owner had them underflated often. Measured every tread block. Outsides are 3/32 and inside are 4.5/32 on front tires. What's odd is I just called discount Tire and got very different prices than last call. It was going to be 90 for mounting and balancing and now it's 16 per wheel. Was 60 per sensor and is now "generally 20 to 40". So his guesstiment was around $150. Last one was $200. Soon as the boys wake up and get some play set time in I'm heading over there.
I just don't feel good about these tires. They have hairline cracks all over, tread is much harder than the tires I just bought(which are eco branded btw), and the raised black lettering looks rough.
What's wasting 2/32 tread on a old tire for safety's sake?
Edited by SnakeEyes
When I start peeling out in the rain at very light throttle, I know it's time to sh**can my tires. :driving:
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
