GM used rivets on S10 balljoints since the beginning. They suck.
Your supposed to replace the whole assembly ad the parts counter would say.
Yep - big ones too. My air chisel knocked the heads off no problem, but won't even touch them as far as forcing them out.
Guess I'd better get the Drill Doctor out ... :mad:
I had to deal with those when replacing the ball joint on my woman's Cobalt, and when I replaced my torsion bar bushings. Major pain in the you know what.
The torsion bar crossmember mount ones aren't that bad with a good grinder. They were really soft when I did mine
The S10's are easy compared to this thing. 1/2" rivets they used, WTF. Spent a couple hours today, and managed to get the bottom of ONE out.
5 broken drill bits. Just broke my 1/2" bit. I'm f#@*ing done! New control arm, or it gets towed out of here.
Guess it's time to retire my GM shirt after this one - that didn't make it either. :lol:
Must be nice. Mine were a pain in the ass.
Its nice not having torsion bars
The farther north you go, the more difficult these things become.
NAPA had a control arm for this turd for $125 with the ball joint. Wish I had done that to begin with. I'd have been done YESTERDAY! Lesson learned.
Finally found something my air chisel could not conquer. First defeat ever. Didn't even move one of them one fraction of a millimeter.
Yea I remember those days from when I had a 900 series pickup.
That IS a steal. Can't touch any around here for less than $25-LARGE. Saw a low mile '05 going for $15k.
Yep- done with new too. Never again. Biggest waste of money in my life. I have the ability to fix them, so I should've never gone new to begin with.
This state doesn't exactly give you much incentive to buy new anyway. Annual excise, and the out-the-door sales tax will give you a stroke. Not to mention insurance. BIG premiums there.
So much easier to go to the store in a beater that you can park anywhere, and not give a crap about it.
Doesn't mean I want it you can offer me a brand new 0 mile 2015 and I'll still turn that problem down
Anyway Fixed big red found out my Bluetooth controller for my halos was drawing current even with the truck off disconnected that and jumped the truck and all is good. Gonna fix my 86 tomorrow
Sent from my SM-G925V using Tapatalk
Edited by SarahsGMC
0 miles is unrealistic. I think my 2010 had 13 miles March 1st 2010.
Mine had 47 on it when I test drove it in April, 2007. 57 when they dropped it off at my house a few days later.
Guess they had to fix a few things first ... :rolleyes:
It was an example guys
You should know better by now to choose words carefully. :lol:
  • Like 3
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
