Keep it going, Dan. Yesterday I purchased a K&N filter for my Duramax. Drop in type. There is a slight sound difference and it does get up and go a little bit better, which I am very pleased with since this thing falls on its face when taking off from a stop sometimes, as well as has bad lag when I need it to downshift. Paid $75.00 at Wally World, not bad vs the $85.00 from K&N website. I'm pleased with K&N products, oil filters, air filters, fuel filters. They stand behind their stuff and have your back if the dealer gives you a hard time over it.
K&N do wear out and then will cause MAF sensor faults like crazy.
I say after about 4-5 cleanings then truck has fits
Edited by Chevor
K&N is junk. Oil all over sensors and they don't filter as good as OEM.
I heard k&n filters for diesels were a bad idea bc the forced induction could suck the oil from the filter and into your trucks intake wreaking havoc
Wow nice guy, I like the way they break down all the time, that's why I'm on my fourth one. My first one is ten years old my daughter drives it now. My Geneses is faster than my 70 Chevelle that I had, and my Santa Fe is a V6 is faster than my 94 impala ss I had that was the fastest Impala except for the 67 427 that my wife's 4 door Geneses will out run. That car is 5 years hard to do with cars of the 60-70s, I was there and own a few.
You're Santa Fe is a piece of shit that is going to let you down, BADLY, you mark my words. Remember, your POS Santa Fe needs a turbo to be fast. The old cars didn't. As for your Santa Fe being faster than the muscle cars of the 60s and 70s? I don't think so. It may be close in acceleration to 60 MPH but the muscle cars can easily outrun your little SUV in the long run. But... moving on.
Yeah, K&N puts performance above filtration. If you can afford engine rebuilds, then I guess that's fine ... but if you want the vehicle to last a long time, they're not the way to go.
I have a K&N CAI, but I only ran the filter for 20k miles before switching to Amsoil (which are now discontinued) filters.
I do still have one on my '74 RD350, mainly because I don't feel like rejetting for a new one. Rebuilding that engine is about as easy & cheap as you can get. No coolant, no valves, no cams. :smoker:
I've had two K&N filters. One of the 88 and one on the 05. It caused nothing but problems on the 05 throwing oil on the MAF sensor. Never again.
<sigh> Ya'll need to learn how to properly care for your filters. I'll leave it at that.
Proper care is buying a conventional filter every 15-20k miles. Oiled filters are a headache with no advantage besides a tiny cost savings.
It's not bad to go with a regular filter on a lot of the newer vehicles anyway. My Cruze is supposed to be changed every 40k or 45k miles I can't remember which. I can get an ACDelco filter on Rock Auto for like $15 shipped. Not really that bad. Just pop the old one out and pop the new one in. No oil or cleaners to deal with.
Edited by Daryl Z71
I'm partial to my AFE filter. I can just blow it out, wash it, let it dry and put it back in. It was pricey but worth it
Sent from my SM-G920V using Tapatalk
The Donaldson filter on my Volant intake is rated for 100k miles. Supposed to be a really good filter
Dad used a lot of their filters on his rigs over the years.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
