Found out I have a bad ball joint. State inspection was due last month, so went ahead and ordered two upper control arms complete with ball joints and bushings. Moog quality, $75 a piece I'll have them by Friday. Gotta love Amazon Prime. Get it in next week for an inspection, body shop will take truck back the 15th to correct their mistakes and some other things I found wrong when I got it back from them after they worked on it after my accident
You aren't exactly a ringing endorsement for that place.
Nope. I will say it's part their fault and part 3rd party adjuster. Based on reviews they are one of the best in my area, about 90% of body shops in my area are just chain places and they all have pretty bad reviews
Cut a hole in the inside of my hood to work the dent out. It's better than it was, but the metal is crinkled now which I was expecting anyhow.
Wouldn't have PDR worked better without needing to cut anything?
Sent from my SM-G360V using Tapatalk
Probably not. It was creased pretty bad plus as many other dents as there are on the rest of the body I'm not paying for PDR. It's getting a new hood eventually anyhow.
Edited by Daryl Z71
I replaced the light bulb on my truck's left headlight.
uggh. I don't envy you.
Brought it home finally, dealer had it since last Friday. There were a couple trucks with pretty much the same problem as mine. Dealer hadn't seen it before so apparently that's why it took so long. The fuel hose near the rail kinked/collapsed. I'm just glad to have my truck back and to have gotten rid of that horrible Encore they gave me as a loaner.
They even put $50 of fuel in it. Forgot to write the mileage down when I gave it to them so I don't know exactly how many miles they put on it trying to diagnose/recreate the problem and checking the fixing of the problem. Got the truck back with more fuel than when I took it in so I guess that's a plus too. Just messes with my super anal logging of everything, oh well.
Geeze try to buy fuel 120 gallons one day, 50 gallons the next and Capital one flagged my card again, gotta send me a new card. GM Buy Power business card is a PITA.
2nd time this year.
2nd time this year.
Really? I have the Buy Power personal card, but dont use it much. Was going to swap it to all my gas purchases
Well, it's awful for over the road driving. Can easily travel over an 800 mile range in 24 hours.
It was so much better when Chase handled the card.
Edited by Chevor
I find everything with the GM badge on it a PITA these days ...
:lol:
I haven't driven her much except to work a few times but she just got 21 gallons of 91 at $2.29! With this tankful she should be hitting 240,000 miles... she's only 62 miles away.
And I should begin cleaning her today, or at least get the mud off. I then need to replace the cabin air filters and check the engine filter, she saw a lot of dust last week.
Drove mine yesterday on about a 115mi trip. Seemed to do pretty good on gas even using the A/C.
Went a few towns over with my zero turn in the truck today to mow my parent's lawn, and to get my brother's lawn mower running that sat outside under a tarp for 3 years. Started one pull with fresh gas. Of course we drained tank and carb prior to putting it there.
Lighting was shooting out of the plug boot -guess it was a little dry rotted, lol. Had a kill switch issue after it ran a while too, which shut it down instantly. After I pulled the top off and fixed it, my brother was holding the plug by the boot as I pulled it over to check for spark. He fell over on his ass after getting shocked, LOL. Has spark now! Then I got shocked putting dielectric grease on the boot while it was running. Figured the grease would insulate better than that. That thing is a menace! :lol:
Had 9 lbs. in the airbags with the 700+ lb. mower in back. Was perfect.
On the subject of mileage, mine SUCKS lately. Might have an issue rearing it's head. Fuel trims have been on the rich side - 12% - probably just under the light threshold. Hand calculated mileage yesterday was 13.6. Normally gets 15 to 16. Should be fun trying to figure that one out. :sick:
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
