Did you get your new wheels on?
Yeah man, they look good. Meet us in York and you can see them [emoji16]
I didn't get a good picture of themost but here was a quick shot once I got home
I got my new vents in. Still need to sell the light gray one
Looks good! Can't wait to see more pictures.
About to hit the road for PA. Can't carry my handgun because I have to go through MD, and they don't honor any other states permits. Such BS
You can take it with you just lock it up away from you. As long as you don't stop in MD you're legal.
Washed, now it gets to sit for a week while I travel for work
Ryan
what tires?
The one I got for free but they split once they mounted em so here I am looking for tires again
Sent from my SM-G925V using Tapatalk
Bridgestone Duravis R500s, they outlast the life of that truck.
I wiped down the truck and car today with a mixture of a scented general purpose cleaner and a minimal amount of bleach. I try to stay away from the door and dashboard plastics but I do wipe down the vents, sills, handles, etc. And all of the cloth definitely gets a thorough wiping.
I also cleaned the glass on both inside and out, dirty glass is a huge pet peeve.
Up next for both cars is an oil change and replacement of the cabin air filters.
Sent from my SM-G550T using Tapatalk
Edited by white1500
Looks like the one i bought a couple weeks ago. I have a low pro LCI and belt clip on the slide.
Good carry gun, my buddy has the same one. I opted for the Glock 43, I should have stuck with my instinct and got me an XDs
Surprised to see a non ca model with thumb safety
Edited by Chris
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
