Going to make my appointment to get rockers and cab corners done soon
Sent from my SM-G925V using Tapatalk
Took my uncle to look for a dress shirt, picked up some food, also stuff to make smores. Stopped for lunch at some Italian restaurant. Most importantly I got my tires sniff and bite inspected. :-)
  • Like 3
Small job -Installed an extra mount and hidden power cord for my Escort max 360 detector so I can use it in the truck on trips.
Normally it lives in the Hellcat.
This seems to be a great detector with many features but it is huge.
Could be anything on these things today. Main reason I NEVER wash my engine or compartment. I'll never dare. Don't need the headaches.
Speaking of headaches ... did plugs and wires on a '02 Nissan Frontier, 3.3 supercharged. NIGHTMARE from hell! Welcome to the 21st century. 8 hour plug job, wtf.
All this for friggin SPARK PLUGS. :banghead:
Also fixed some idle issues it was having. The TPS on this thing has a dual function of a TPS, and an idle control. Thing looks brand new, but whoever installed it BUTCHERED the 4mm screws. Luckily I happened to have a whole box of hex head bolts in the same thread pitch. Miracles never cease. Used the new Autel to perform an idle relearn. Running great now.
Not impressed with the power output of this thing being supercharged and all. Felt pretty weak to me.
Isn't that the truck that used a supercharger to take a 160HP engine to a massive 190HP :lol: . Nissan really dropped the ball on that one. Edited by SnakeEyes
I believe they only used an Eaton M90 on it. Same blower as the Pontiacs used with the 3.8
My favorite is the Nismo pickup with no rear locker
Sent from my SM-G920V using Tapatalk
They got the idea from the Z71 2WD. :lol:
Yeah, it's pretty bad. My brother had the exact same but N/A engine in his Exterra - thing was completely sackless, and consistently got 13 MPG. Not a very efficient design. Reminds me of Chrysler's 360 in the early 80's.
Yeah, my wife's sister had a Frontier with the 3.3 160. Super reliable but rode in it one day and thought we were going to get killed when she floored it onto the highway. She had a crew cab long bed! Now she has a Trax. Guessing she's never had a speeding ticket. :lol: Edited by SnakeEyes
Oh wow, I can imagine! The supercharger in a regular cab short bed is barely enough power as it is.
Wikipedia says the blower only added like 30 HP! That's terrible! But those trucks were dogs.
LOL, yeah that's pretty pathetic! I'd bet with twin turbos, the OEM supercharger, and a big shot of NOS, it would still be under 300 HP. :lol:
And every Chrysler since :)
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
