GMPP Touring Muffler
Just ordered the sport muffler for my 6.0L 2500HD. Has anyone installed one on this engine. I think my pipes are 3", but i'll make it fit...
  • Replies 181
I installed one for someone with the HD and the ends are able to be puffed to fit. If you don't have the tools to do it, just use 3"to 2.75" adapters. Sounds much better on the 6.0 btw.
Sent from my iPhone4S
using Tapatalk
Got my Borla Touring muffler in the mail today. Now that I have both, I will be doing a full comparison between the Touring & the Sport series on dimensions, sound, mounting, and looks very soon.
I finally got my touring muffler installed two days ago. Sounds great going down the road. Funny I seem to hear it more when I have the windows rolled up than with them down while driving in traffic. I haven't gotten it out on the highway yet. The idle is a little softer than what I thought it would be. But overall, I am very happy and pleased with it, especially since the truck still has the stock look.
Is there a flow direction (inlet/outlet) on this muffler?
Sent from my DROID RAZR using Tapatalk 2
using Tapatalk
Thanks for the info..... I had a Corsa Sport on my 02 HD but sold it. Wanting a different muffler on my 10 HD it sounds like Borla is going to be it.
No flow direction from what I can tell.
I couldn't see anything either but wanted to make sure. Thanks
MPG Update:
After 4 tanks of gas I have noticed approx. 0.5 MPG increase in city driving and slightly over 1 MPG increase on Highway driving.
MPG Update:
that's about same for me
MPG Update:
That's on par for what I am seeing also, after 3 tanks of 87 octane Shell gas. 1.0 - 1.2 mpg increase at 70mph on the freeway over a 100 mi trip. Previously pulling 19.1 - 19.3, now pulling 20.1 - 20.3 mpg.
And BTW, I also installed a Airaid MIT jr kit with their synthetic dry filter.
Also, I finally got my GMPP Borla touring muffler mounted up to give a comparison of both the Touring & Sport version on my truck. Enjoy!
Touring:
Sport:
Whos got pics of install? Local shop wants 197, and re bend the whole tail.
Sent from my ADR6400L using Tapatalk 2
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
