Carpet soaked under floor mats
Had my A/C cranked up today, temp. was in the mid '90's. Got home and noticed my carpet under both front floor mats was completely soaked. I also had fog coming out my vents a couple times and had some water drops coming from my center vents. Anyone else had any symptoms like these? What would be causing this?
sounds like your AC drain plug is plugged..from the engine compartment under your heater box, you should find a small brain tube. take some pipe cleaners and check if the drain tube is clogged. you be surprised at what can get in there..biggest issue are leaves,mud/dirt and spider eggs.
good luck
Thanks. That's the only thing I could think of. I'll check it out.
