Wow! I picked up 3 mpg.....
Those of you who "Drove it like you stole it", probably won't like this.
I love my truck, but hate the 16 mpg it is getting, but would rather have that than a small car. I have the 09 Silverado Ext cab with the 5.3L and the 4 speed, with the 3.73 rear end and 20" wheels.
If I could only figure out a way to get 4 mpg more, I thought, I could save at least $10.00 each time I filled up.
I have had my hours cut drastically at work and now every dollar is starting to count. So I thought if I could save some gas it would be a start.
So I started to change my driving habits to see if maybe I was too aggressive of a driver, (lead foot). Well, I do like the sound of that V8 rumbling as I accelerate.
So I decided to change some things, like slowing down my speed.
I slowed down and now drive in the far right lane and keep the speed around 60 if the speed limit is 65 and about 65 if the speed limit is 70. That way I am not in the way of the 18 wheelers.
I use the cruise control as much as possible, and just sit back and relax.
I don't accelerate as hard from stop signs and lights, since I am not in a race.
I noticed over the past few years that when I take my foot off the gas pedal the truck doesn't have much compression to slow it down and it will coast quite a ways, so I use that to my advantage and coast the last 1/2 mile on the freeway to the exit and my speed may drop down 3 - 4 mph which doesn't affect the traffic much if at all. I also do that when in town and I see a red light, I take my foot off the pedal and the truck will coast to the light.
Little things like this has really helped.
I noticed that since I got gas last time, I reset the Avg fuel and also the gallons used on the DIC and found that the Avg Fuel Econ is now indicating just around 19.8 to 20.2 mpg, which it used to show around 16.9. Now don't get that confused with the Inst Fuel Econ which varies anywhere from 2 mpg to 99 mpg and changes according to the pressure of your lead foot.
Of course this is while driving with the truck empty and I haven't taken any long trips. I drive about 20 miles each way to work, which is about 18 miles freeway and 2 miles city driving.
I just hope I can keep my foot out of the carburetor. Wait...I guess it should say..."Keep my foot out of the fuel injectors". :fingersx:
Anyone else have ideas on how you save gas while driving?
  • Replies 30
Awesome. Hard to believe that makes up 3 or 4 mpgs. Yes, I'm stuck at in the 16.9 range too, but I have nowhere near enough self control to accomplish what you did.
Clean air filter, and proper tire inflation will help as well.
I have found the more that you use cruise control and do not go over 65 fuel economy goes way up.
I agree. It's actually amazing how "good" fuel economy these trucks get on the hwy.
I drive 28 miles to work, bout 20 on the freeway. I avg 18mpg with out driving under the speed limits, sometime on the way to work it 70 in a 60, hanging with traffic. Mostly freeway i did avg 20.3. Btw all my mpg are done by hand.
Sent from my ADR6400L using Tapatalk 2
Performed a similar experiment with similar results not too long ago. If I drive the way I'm "suppose" to I can pick up at least 2 mpg, however I can't keep driving like that around here. "Drivers" around here irritate me too much to maintain proper road "manners". My drive is all city type driving roadways so I only get to see 20mpg (or there abouts) if I take a road trip.
I pick up about 2 mpg going 70 instead of 75-80. Also try to keep my foot out of it. I've found that speeding up too slow will hurt more than help though. I try to speed up reasonably, and then lock it at a reasonable speed. Unfortunately my mileage sucks no matter what when I'm driving on dirt roads
Anytime I have ever used cruise control I use more gas. Now this is driving "Up North" from downstate Mi where there is a lot ot terrain changes. I have found using the cruise just "kicks it in the ..." to get up the hill, but by "feathering the throttle" you can get better mpg. Also using the downhills to get up the next hill helps a lot, just make sure there isn't a "Boy in Blue" (State Trooper) at the bottom of the hill! Lol
Chris
Chris
Same here, I get better MPG without cruise controll. Accelerate slowly downhill and coast uphill.
You can do that with the cc on just help it keep going
My best is 18.5. I lost 2.5mpg when the ethanol mandate went in effect. I also lost another 2 when I put on these BF Goodrich 285 series tires. I have to drive really careful around town to get 14.5mpg. I'd be happy if we could get rid of this ethanol!!!
I just drove from Pontiac MI to Holland MI and got 18.1 mpg. I have 214,000 miles on the truck with 8 ply 285/75/16. Stock exhaust but with the performance tune from superchips. I went 264.4 miles on 14.6 miles. I filled up when we left the hotel and when we got back into holland. I was pumped because there are a lot of ups and downs. That was also traveling around 65 when the temp was 90ish.
In Vancouver we have a lot terrain changes. Up and down. I'm better of without using the cruise control. As stated before my food is much more sensitive than the cc.
OP.
Take all unnecessary stuff out of your truck. Especially in hilly areas you will see a difference.
Coasting is the magic trick. Every step on the brake pedal is a waste of energy. It takes a little while to get used to it without being a traffic block.
Flow with the traffic. Leave a little space to the car in front of you. So you don't have to brake and accelerate every time. Leave the truck rolling in idle. Most of the time the cars in front of you start moving again until you catch up.
Plan and connect your trips. Coming back from work? Why not stop at the grocery store on the way instead of driving home first to have a coffee?
I'm not really sure about it but I think the air condition is better for the fuel economy than open windows. Please correct me if I'm wrong.
There are so many thing one can do. And it can become a challenge... :) .
Drove my truck 2 weeks ago to Alberta and back (over the mountains).
2250km @ 12.3 l/100km (19.1 mpg).
Edit: plus 1 quart of oil...f*^!_ing AFM... :fume:
so long
j-ten-ner
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
